Old 22nd May 2003, 08:05 PM   #1
Default pre-amp schematic
Here is an attached schematic of my pre-amp I am building.
The supply will be run of 3 12V batteries.
Was going to use BG for the 100uf supply cap, but with the issue of discharge in these caps... probably not.
So... looking for ideas to use for this cap...?
Use Riken for the resistors.
Ideas for output coupling cap???
Does the BG Cancelling pair using NP have the same discharging effect as the others?
Any recommendations on the pre? Gain is around 6.
Old 22nd May 2003, 08:16 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
What issue do you mean ?
It's only audio
Old 22nd May 2003, 08:19 PM   #3
Default issue
The issue is with that BG caps need a very long break in period, and if you turn the pre-amp off, next time you tuen it on, needs several hours for best sound.
With battery supplies.... keeping them on for more than a couple of hours is difficult.
BG caps sound the best when the equipment they are in is left on all the time...
so I have I been said....
Old 22nd May 2003, 09:05 PM   #4
lohk is offline lohk  Europe
lohk's Avatar
This circuit is almost similar to the TNT Preamble. They use 10k for your R6 instead of 1k and 40V supply voltage.
The output cap should have a higher value, at least 8 - 10yF.
Klaus
Old 22nd May 2003, 10:58 PM   #5
jean-paul's Avatar
Default Re: issue
Apart from the break-in period this is nonsense. Don't believe everything people say, better try it yourself.
The break-in period can be shortened by putting the caps on a power supply for some weeks.
It's only audio
looking for a pre-amp schematic steamPunk Tubes / Valves 3 3rd August 2008 01:49 PM
DBX 500 schematic d3imlay Solid State 0 2nd August 2008 05:12 PM
F3 schematic kenev Pass Labs 2 24th January 2008 03:24 PM
Need Six-pac amp schematic Sarge Tubes / Valves 1 31st July 2004 08:30 PM
Page generated in 0.08577 seconds (71.16% PHP - 28.84% MySQL) with 11 queries
