The attached buffer is designed as the output of a balanced line amp.
If I run the simultation as in the attached cct diagram and look at 20KHz distortion of Vo1, I get around 70ppb (70ppb). If I place a ground between the 2 power supplies the distortion increases to 6.9ppm (6.9ppm) - a deterioration in performance of 2 orders of magnitude. I only discovered this because I accidently left of the ground between the power supplies. When I put the ground in, the problem arose. I tried a second experiment. I removed the ground between the output load resistors and with the power supply ground removed, the distortion increased to 1.3ppm (1.3ppm). The 3rd experiment is with the PSU ground in place and the ground between the load resistors removed. Distortion is 6.2ppm (6.2ppm). So, the key issue is the PSU ground. Is this an LTspice or model problem, or am I missing something more fundamental here - e.g. are the distortions cancelling when the ground is removed? Dazed and confused |
#2 | |
In any case, the situation with supply ground is the 'real' one of course. jd
/Another new issue: Linear Audio Volume 3! |
#3 |
Thanks Janneman. I get 3.5ppm single ended (which to me seems like reality). I'm concluding that the 70ppb no grounded PSU result is indeed due to distortion cancelling, though I don't think this is a practial connection scheme - the whole thing will be floating around. This result sort of reminds me about balanced symmetrical amps with current mirror loads on the LTP . . .
| Lowering Buffer Opamp Distortion | mrfeedback | Solid State | 9 | 8th January 2009 04:16 PM |
| Simple Low Distortion JFET Buffer | wrenchone | Solid State | 21 | 29th January 2007 08:16 PM |
| Best low-noise low-distortion buffer? | borges | Solid State | 7 | 9th December 2003 12:40 PM |
| Opamp + buffer, how to bypass buffer at HF for unity gain? | Christer | Solid State | 10 | 29th October 2003 06:50 AM |
| Page generated in 0.06679 seconds (81.95% PHP - 18.05% MySQL) with 11 queries |
