"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? "Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name? - Page 5 - diyAudio
Old 27th February 2011, 01:10 PM   #41
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Originally Posted by WuYit View Post
tiefbassuebertr,
I gave a clear explanation, after some pondering you should accept it. The operation mode can either be balanced or unbalanced with distinctive difference in function and sound characteristics. There`s no third possibility.
The circlotron circuit provides balanced operation: push-pull in its purest form.
Härzliche Grüße
I gave a clear explanation, after some pondering you should accept it....
No, because a clear explanation looks substantially different from your explanation.
Check out e. g. the term "Single Ended".
Even in case of amp topologies this term is ambiguous. The opposite term is either "Balanced" in case of the input stage (if there are differential input amplifier stage instead "single ended" amplifier input stage) or "Push Pull" in case of the output (buffer resp. power) stage.
Both haven't to do with the terms "quasi complementary" or "true complementary", because this both terms are in all cases "Push Pull" (in case of output stages).
Improve your skills befor you continue your discuss.
Originally Posted by f117 View Post
Since we can use the same polarity device for output, why the complementary is the most common?
Because most engineers are too lazy (sometimes even unable) to develop truly innovative amplifier topologies.
But exceptions prove the rule:
www.passlabs.com (aleph series and "First Watt" e. g.)
and
http://www.diyaudio.com/forums/blogs...eek-tweak.html
and the URLs about
http://www.diyaudio.com/forums/solid...put-stage.html
2N3055 inside - commercial famous amplifier models, quasi complementary power output
Old 27th February 2011, 03:34 PM   #42
WuYit is offline WuYit  Sweden
Banned
tiefbassuebertr,
now I´m a little bit disappointed with you. Don´t get hung up on the names, look at the function. The definition is unambiguous, explanations can be muddy.
Old 9th March 2011, 02:08 AM   #43
ANADIGIT is offline ANADIGIT  Europe
Banned
Default Its PCB !
I got it ! Hooreyyyyy !
Thanks for ebay that recorded very old item of this seller.
I bought them only 50USD.
Full screened label and operating test point but it used very expensive power mosfet 4Pcs (94USD a piece), how do I find APT10025JVR from Microsemi.
Anadigit
Old 24th March 2011, 03:40 AM   #44
Banned
Default New Sink !
I have got a new heatsink of driver board already. It's look like nearly close to original design of Gamut.
Second plan are finding Plittron 55-0-55 / 5A, 18-0 / 1A transformer and 22000uF/100V RIFA
Anadigit
Old 24th March 2011, 04:41 AM   #45
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
RS Components list some of those devices, all N-channel, most of them ixys
Old 6th April 2011, 02:21 AM   #46
Banned
Default Update
Last updated for Gamut chassis and supply. I try many times to build its chassis but I can't succeed for a log time :-(
Old 8th April 2011, 03:13 AM   #47
Banned
Default Completed !
This's my clony of Gamut :-)
I used only typical TI opamp and 1% royal resistor.
Hooreyyyy asap to hear it !
Old 14th April 2011, 10:21 AM   #48
Banned
Hi, everyone 1
I need to use Gamut circuit as my car audio amplifier. Could someone suggest me about SMPS to get +/- 70V and 25VDC both voltage rails should ground isolated together.
A big project !!!
Anadigit
Old 14th April 2011, 12:47 PM   #49
MiiB is offline MiiB  Denmark
Look at ESP page he has a well proven design
Old 14th April 2011, 07:42 PM   #50
this design?
Switchmode Power Supply For Car Audio
here other URLs:
http://www.scribd.com/doc/4071900/Sw...-for-Car-Audio
http://www.smps.us/smpsdesign.html
some years ago there was also such a project in the German magazine "Elektor".
"Push-Pull" for push und "Push-Pull" for pull (like Gamnut) - whats the right name?Hide this!Advertise here!
"Killer" Screen Driven Push-Pull Amp Initial Queries wrenchone Tubes / Valves 55 7th September 2014 11:39 PM
829B/3E29 "Triode" Push Pull Paralleled Sections coldcathode Tubes / Valves 26 28th October 2010 06:39 PM
Chip amps used in "push pull" ChrisA Chip Amps 22 2nd July 2009 09:18 PM
Kofi Annan in: "Push and Pull with Me" Kofi Annan Tubes / Valves 340 6th November 2006 03:18 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 3rd November 2005 11:25 PM
Copyright ©1999-2017 diyAudio
