Old 11th November 2009, 06:22 PM   #1
Default Harman Kardon Citation 12 crunchy low volume output
Hello
I just got ( from Ebay...) a perfectly working Citation 12 power amplifier.
Just plug it in via an Adcom Preamp and CD to found out that both channels plays very low and full of parasites. Well I measured the HV out of the filter caps and there are stable +-41V. Also the Bias is fine as described on the techical manual. What might be the problem ???
I looked around the schematics and noticed these brakers for the output but on the Ohmeter they show .5Ohm so I guess they work.
Any ideas ?? or should I scrapt it since I have an ADCOM GFA-535 in fine working order.
Thank you
George
Old 12th November 2009, 06:51 AM   #2
Mooly's Avatar
Impossible to say. Would have to see circuit and at least do a couple of basic tests.
The fact that it seems DC stable with correct bias means it must be 99% OK IMO
Two minutes with a scope and signal generator would reveal all
Old 12th November 2009, 07:08 AM   #3
Frank Berry's Avatar
Pull the circuitboard and replace all of the electrolytic caps on the board.
Use DeoxIt or some other red oil to clean the little finger contacts on the bottom of the board.
That should bring the amplifier back to life.
The Citation 12 is a fine amplifier.
Frank
Looking For Harman Kardon Citation 11 Manuals PB2 Solid State 1 6th May 2009 06:46 PM
harman kardon citation 12 joka22 Solid State 6 23rd November 2008 11:25 AM
Harman Kardon Citation 16 Tom469 Solid State 5 2nd February 2008 01:18 PM
schematic request: harman kardon citation XXp renehuot70 Solid State 3 24th June 2007 12:58 PM
Harman Kardon CITATION 24 data sheet santosa Parts 0 16th March 2005 11:17 AM
Page generated in 0.07796 seconds (70.02% PHP - 29.98% MySQL) with 10 queries
