Old 11th November 2009, 01:37 PM   #1
IG81 is offline IG81  Canada
IG81's Avatar
Default Emitter follower related question
Hello,
When biasing an emitter-follower with a current source in the place of a typical emitter resistor, can the equivalent emitter resistor be calculated by V-emitter / I-emitter?
I need this value in order to calculate input and output impedances.
Thanks!
Old 11th November 2009, 01:50 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally Posted by IG81 View Post
Hello,
Thanks!
The impedance from the current source can be calculated from delta-V/delta-I. That is much higher than Ve/Ie. So what you see from the base is that very high Isource impedance in parallel with the load, and most of the times it will be the load that dominates, meaning you can disregard the Isource.
The input impedance looking into the emitter is that Isource in parallel with whatever the impedance into the emitter itself is, and the latter will dominate, meaning you can disregard the Isource.
jd
/Another new issue: Linear Audio Volume 3!
Old 11th November 2009, 02:21 PM   #3
IG81's Avatar
Thanks for a quick answer janneman.
If I understand correctly, I can disregard the Isource impedance and simply use Rload in my calc.
How about for the base? I also have a current source in place of the base-to-ground resistor in the "voltage divider", how does that go?
ig
Old 11th November 2009, 02:29 PM   #4
janneman's Avatar
ig
Well in any case the Isource is (very) high impedance. So the impedance of the base divider is the Isource in parallel with the resistor from base to supply (remember that for ac and signal, the supply is considered ground).
But do you have a circuit diagram? I suspect what you are trying to do at the base will not be thermally stable and might need individual adjustment for each device.
jd
Old 11th November 2009, 02:47 PM   #5
IG81's Avatar
Here's what it looks like, don't look at component values, just topography.
ig
Old 11th November 2009, 03:03 PM   #6
janneman's Avatar
ig
Can't find anything wrong here.
jd
Old 11th November 2009, 03:51 PM   #7
IG81's Avatar
jd
So for the input Z of the circuit, can I also "neglect" Isource and just use the +rail-to-base resistor || with Zin-base?
Thanks,
ig
Old 11th November 2009, 04:31 PM   #8
janneman's Avatar
Thanks,
ig
Well, depends on the resistor values. If the Isource has 150k dynamic impedance and the other R is also 150k, clearly you can't ignore Isource: the parallel value is 75k.
If the R is 10k, the parallel value is about 9.3k. Are you familiar with calculating parallel impedances?
jd
Old 11th November 2009, 05:00 PM   #9
IG81's Avatar
jd
Yeah, it's more how to translate a current source into an impedance that I was looking into here. I think I can see what you mean by "dynamic impedance" that should not be neglected if the lower Z it can take is not big enough to make the parallel impedance be close enough to the resistor above.
az
Old 11th November 2009, 05:22 PM   #10
janneman's Avatar
az
An Isource can be considered as an impedance but you can't measure it by its voltage over its current. You measure it by varying the voltage a bit and see how the current varies, then the impedance (the dynamic impedance) is delta-V/delta-I. Ideally, the current doesn't vary with voltage and then the dynamic impedance is infinite...
jd
Triple Emitter-Follower as OPS for the Aikido teodorom Solid State 7 5th June 2007 09:55 PM
Offset Compensated Emitter-follower... mikeks Solid State 24 5th June 2006 08:10 PM
Complex Emitter follower Banfi T. Solid State 104 1st April 2003 10:05 PM
Help a nOOb out with an emitter-follower... EchoWars Solid State 8 8th January 2003 09:40 PM
Page generated in 0.12232 seconds (79.11% PHP - 20.89% MySQL) with 11 queries
