Emitter follower related question - Page 2 - diyAudio
Old 11th November 2009, 06:35 PM   #11
IG81 is offline IG81  Canada
IG81's Avatar
Originally Posted by janneman View Post
An Isource can be considered as an impedance but you can't measure it by its voltage over its current. You measure it by varying the voltage a bit and see how the current varies, then the impedance (the dynamic impedance) is delta-V/delta-I. Ideally, the current doesn't vary with voltage and then the dynamic impedance is infinite...
jd
Are we talking collector voltage and current here? I could simulate this by changing the value of the collector resistor, correct?
ig
Old 11th November 2009, 07:31 PM   #12
jan.didden's Avatar
ig
If you sim your Q1 circuit from above, you can vary the voltage at the end of R2 & R3 (the supply) and measure the variation in Ic (you could measure VR4).
You can also supply R2 & R3 from different supplies, and keep R3 supply (that biases the cs) constant and vary the supply to R2 and see how taht influences the current. It will give you some idea of the impedance.
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 12 is out! Check out my Autoranger and SilentSwitcher
Old 11th November 2009, 08:15 PM   #13
IG81's Avatar
I simulated a stand-alone current source loaded with a resistor.
I did it the way I described, by changing the load resistor, and the way you described, by varying supply voltage. In both cases, deltaV / deltaI were close enough, as my measuring ranges were a bit different.
I guess the thing when performing this is to use a delta that stays into the transistor's linear range, as things get out of whack at cutoff and saturation. Any recommended range of deltaV ?
az
Old 11th November 2009, 08:40 PM   #14
jan.didden's Avatar
az
For measurement or sim you just select a delta-V within the linear region because that is where the circuit is supposed to work.
jd
Old 11th November 2009, 09:54 PM   #15
godfrey is offline godfrey  South Africa
The variation is small. For a current source like Q1, the "effective impedance" looking into the collector is typically in the order of 1000 times the value of the emitter resister - i.e. in this case several tens of kilohms - probably about the same as R1 and also about the same as Q2's input impedance (assuming a current gain of a few thousand for the output stage).
Input impedance of the amp as a whole is a parallel combination of R1, R2, Q1's collector, and Q2's base. R2 will totally dominate and I'd expect an input impedance of about 1K4 overall.
I'd consider Q1's contribution to be negligible, but if it bugs you, you could always use a better current source like one of those in the attached gif. I'd vote for the one on the right.
Old 12th November 2009, 02:55 PM   #16
IG81's Avatar
That second current source is certainly more elegant than using diodes. I'll redesign around that for sure.
Thanks for the advice and help guys!
ig
Old 16th November 2009, 01:51 PM   #17
Hi IG
Sorry if this is a bit late but ....
The original circuit is going to have quite a bit of hum, mostly injected by the 1k5 bias resistor to the base of Q2, and also a little bit via Q2, Q4 and Q5 even if Q2's base voltage is clean.
An easy way to get super-clean results is just to use a positive-earth arrangement (see attached simplified schematic).
This way, there's no signal current flowing through the power supply, either (for those who care).
The capacitor I added to the bias network is kind of an optional extra - will help with the hum too, but mostly I'm thinking you might need something like that to tame the switch-on thump.
The monster output caps are nice but if you're not careful, your speakers are going to be doing some serious stretching exercises every time you switch on (not sure about switching off - you can have fun modeling that)
The other attached circuit is just how to hum-proof a current source with a zener. Tip for when you have free choice of zener voltage: those around 6V are the stiffest i.e. lowest delta V / delta I.
Right, time for me to shut up and let you get on with it
Triple Emitter-Follower as OPS for the Aikido teodorom Solid State 7 5th June 2007 10:55 PM
Offset Compensated Emitter-follower... mikeks Solid State 24 5th June 2006 09:10 PM
Complex Emitter follower Banfi T. Solid State 104 1st April 2003 11:05 PM
Help a nOOb out with an emitter-follower... EchoWars Solid State 8 8th January 2003 10:40 PM
Copyright 1999-2017 diyAudio
