Old 10th November 2009, 03:07 AM   #1
Default Blew up JFET's on Preamp
Here is my power supply.
http://img.villagephotos.com/p/2003-4/144711/DOS317.gif
I have the system ground running to AC ground, and I am wondering if this caused the problem.
The pre-amp is just four JFETs and five resistors. The shunt to system ground (AC ground in my case in this instance) from the input is 510kohm.
15 - C
http://www.borbelyaudio.com/adobe/ae699bor.pdf
My neutrals on the RCA's are all connected.
I just want it to work! I do not have any heatsinks on the LM137's either if that matters... There is such low current....
The JFET's connected to the -24v blew up when I plugged it in. I just discovered another accident which was there was no load connected when I first turned it on either. There was not connection being made via the RCA's.
Old 10th November 2009, 03:40 AM   #2
Somewhere in the process my volume Pot got completely burned out as well.
Old 10th November 2009, 04:03 AM   #3
CBS240 is offline CBS240  United States
CBS240's Avatar
Are you sure the gate of the lower fet (CCS) is connected properly? Without the gate connected, the CCS fet, as a depletion device, would be fully on, which would cause the top fet, the follower, to be fully on as well.
All the trouble I've ever been in started out as fun......
Old 10th November 2009, 04:06 AM   #4
Oh and my 3875 Chips in my amp are toast.
If my DAC is toast I will never probably have a stereo again for a long time....
Old 10th November 2009, 04:09 AM   #5
They are 170BL's... If you look at them from the front the right pin is +24v center is signal, and left is drain (out). Then on the other one it goes drain from other into the pin on right, then middle and left are jumpered via resistor, and -24v is connected to the resistor side away from the FET.
Old 10th November 2009, 04:19 AM   #6
PSz. is offline PSz.  United States
PSz.'s Avatar
Did you use coupling caps?
psz.
Old 10th November 2009, 04:25 AM   #7
Where at? The input or the output?
Neither. My DAC has them and the amplifier seemed fine without.
Old 10th November 2009, 05:25 PM   #8
Anyone Know why the JFET's blew? I assume that has everything to do with all of my other equipment but...
Old 11th November 2009, 03:12 AM   #9
Looks like you got the pins reversed.
Mike
AmpsLab.com
Inexpensive JFET Preamp jonusgrumby Solid State 115 28th June 2011 04:46 PM
JFET preamp? asc Chip Amps 4 12th July 2005 07:44 AM
JFET preamp recommendation? leadbelly Solid State 10 30th March 2004 02:56 AM
Jfet preamp secret leiade Solid State 14 16th September 2002 01:26 AM
Page generated in 0.09931 seconds (79.60% PHP - 20.40% MySQL) with 11 queries
