Old 8th November 2009, 10:42 PM   #1
Default A&R Cambridge A60 Amp left channel very low distorted
Hi folks I am new to this forum.
I have an old A&R Cambridge amp, the faults it is currently displaying are:-
1 Noisy operation of volume control
2 Very low output from left channel ( if you turn up the volume the sound produced is very distorted).
At first this would only happen after a few hours operation, now its permanent. I suspect something has overheated but can't see any evidence of this when I look inside the amp.
Anyone care to offer advice on how to fix this?
I've just taken the amp out of storage it hasn't been used for the last 15 years
regards
Barry
Old 9th November 2009, 08:21 AM   #2
jaycee is online now jaycee  United Kingdom
Arcam will quite happily send you the schematics of the amp if you ask them to. They're great in this regard! Make sure you tell them your serial number so they can tell you the correct schematic to use.
If memory serves, a common failure is a muting FET, which causes these symptoms. There are a few different versions of the amp so you need to find out which one you have.
The noisy volume control is most likely as simple as the volume pot being dirty or worn. A replacement pot should be easy enough to get.
Old 29th November 2009, 08:24 AM   #3
Hi Jaycee,
Thanks for the advice, I tried to contact arcam via email from their website, all I got back was an out of office auto reply stating they would deal with my inquiry as soon as they could.
I have now fixed my amp one of the power transistors was faulty I replaced all four just to be sure and ajusted the quiescent current. The amp is now sounding wonderfull.
Thanks for your advice
Barry
Old 18th May 2010, 08:13 AM   #4
wabun is offline wabun  United States
I have the A75, Cambridge Audio power ampo schematics, do u want it ? if u do, PM me and I send you a copy..
ppi pc2150 distorted right channel 67elcamino Car Audio 16 29th August 2009 06:46 AM
Distorted left channel - Marantz 2385 jblmar Solid State 2 27th March 2009 05:04 PM
Distorted left channel Proton 520 Amp allank Solid State 1 13th September 2006 01:41 PM
put my pre-amp together and now the left channel is playing distorted :( elizard Solid State 21 4th April 2003 06:23 AM
Help!! Right Channel Freq distorted. TPC Tubes / Valves 3 16th January 2003 02:27 PM
Page generated in 0.06592 seconds (83.34% PHP - 16.66% MySQL) with 10 queries
