#12 |
keep the soft start for the transformer as it is. Should allow a low value fuse and a delay of ~200ms.
Add a slow charge circuit to the secondary side. A couple of high current Power Thermistors with a 5s delay on the bypass relay/s.
regards Andrew T. |
#13 | |
Do not lengthen the delay for the relay. It does not reduce the inrush current. It is the Main resistor that does the current limiting. Keep the delay short, less than 1 sec. This will avoid stressing the current limiting resistor. A variac should never be used to test this circuit. The Main resistor will burn out due to the prolong delay before the relay is activated. Also, some amplifiers, a small number, will blow if they are powered up with a variac. A practical approach to determining the value of the current limiting resistor is to adjust it for about 2/3 of the rails voltage. Say the amp has working voltages of +/-80Vdc. During power up, adjust the Main resistor for 55-60V. Once the relay kicks in, the rails will shoot up to 80V. You will be able to see this with a scope. A more scientific approach is a use a Clamp Meter that measures Peak current. That will tell you the actual current surge. Adjust the Main resistor accordingly. Mike
AmpsLab.com |
#14 | |||
Thanks for the response Andrew , wouldn't 5 sec be 2 long ? |
#15 |
no, 5s to 10s for the slow charge thermistor bypass is OK.
The soft start resistor must be bypassed a lot sooner, 100ms to 300ms. I think 1s is too long for a mains resistor. 47r across 110Vac is about 257W. How hot will it get in 1s?
regards Andrew T. |
#16 | |
Thanks for the input . You suggest increasing the resistor value to as much as 33 ohm from 4.7? I had thought about upping it to a 30 watt , so i will now consider a higher imp by using a 33 ohm do you think the rest of the circuit will be sufficient ? I do not have a clamp meter , so I'm not able to adjust as you suggest and was going to increase the resistor to 12ohm/30 watt .. do you still suggest 33 ohm ? |
#17 |
a 33r will limit the worst case start up current to <=5Apk. That sounds about right for a 110/120Vac supply and a close rated mains fuse.
I use 50r for 240Vac
regards Andrew T. |
#18 | |
so you agree to increase the 4.7 main resistor to 33 ohm ? of course any changes will include higher wattage to at least a 30 watt resistor , would you still add the thermistors to the circuit for the additional caps ? or will my original suffice with the resistor upgrade ..... |
#19 |
Electrons are yellow and more is better!
Mr. Wayne, how low impedance do you have really?
The waveform of the current is short spikes which creates over tones the mains and they may interfere with other apparatus connected to the mains. Your rectifier bridge will have a harder life and also the transformer. The VA rating becomes half the value if you have a huge capacitor battery. A 500VA transformer can only take 250 VA if you have a PSU like this.
/Per-Anders (my first name) or P-A as my friends call me |
#20 |
Main fuses are @ 15 amps rated .........Peranders low is 1.2 ohm
| Soft Start Necessary? | dtaylo3 | Class D | 2 | 26th December 2008 10:05 AM |
| B+ soft start | Gluca | Tubes / Valves | 2 | 3rd September 2007 02:04 PM |
| Need a soft start? | maxpou | Solid State | 19 | 18th April 2007 10:23 PM |
| Soft start & Soft Switch circuit: can anybody help? | m.parigi | Solid State | 95 | 22nd August 2005 04:32 PM |
| Page generated in 0.13443 seconds (75.84% PHP - 24.16% MySQL) with 11 queries |
