Your opinion about this schematics?
View Poll Results: How many amplifiers have you built?
1-3 20 20.00%
3-5 13 13.00%
more of 5 65 65.00%
none 2 2.00%
Voters: 100. You may not vote on this poll
Old 5th November 2009, 04:03 PM   #1
Pigy is offline Pigy  Serbia
Question Your opinion about this schematics?
Please, tell me your opinion,about this old schematics.
I know that this schematics is old,low hi-fi,but easy to building, and cheaping.
Yours experience?
Old 5th November 2009, 05:14 PM   #2
hollow_man is offline hollow_man  Europe
Power Supply Rejection Ratio (PSRR) looks like is going to be really poor, so you may end up having considerable hum. Ii may be cheap, but it be worth the trouble?
'in acts and works
bigger than a great wale's tail'
Old 5th November 2009, 05:25 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
It is a typical old AC coupled design. Build it if you have a PCB for it, otherwise choose another amp with a PCB that is known good. That amp is no simpler or easy to build than may other amps.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 5th November 2009, 06:22 PM   #4
Mooly's Avatar
Old it may be but you may be surprised just how good it may sound. Look at the feedback factor.
It's ideal as a first project IMO, you have no worries about DC problems damaging speakers and the PSU will be simple.
It will work with just about any suitably rated transistors too...
Do you have the full construction details ? showing how to set up the bias etc and having T3 in thermal contact with the output transistors to keep it from thermal runaway.
Old 5th November 2009, 06:40 PM   #5
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default It is very good...you gonna be happy with it.
Do not bother with modern and fashion circuits.... an enormous ammount of them sounds awfull.
You know when something sounds bad when you go tweaking tone controls and never feel satisfied..then you go to tweak your speakers, and then you replace speaker and speaker crossovers.. and then you tweak your home acoustics ..and continue not happy.... this happens when sound is no good.
When the amplifier is good you do not even need tone controls, all musics sounds good, nothing to tweak...it is easy that way.
regards,
Carlos
Old 5th November 2009, 11:58 PM   #6
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
"Old it may be but you may be surprised just how good it may sound. Look at the feedback factor.
Do you have the full construction details ? showing how to set up the bias etc and having T3 in thermal contact with the output transistors to keep it from thermal runaway. "
Solid Advice.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 6th November 2009, 08:26 AM   #7
Lumba Ogir is offline Lumba Ogir  Sweden
Banned
Howdy,
this is great sounding topology with scope for further refinements.
No thermal runaway.
Old 6th November 2009, 01:35 PM   #8
Dear frends, T3 is bias control, this transistor shold be to put in to heatsink with outputs transistors,think in same place(heatsink, because good termal stabilty) .
About hum,yes that is probably problems,but with BC550,and metal films resistors,maybe hum to be low.
This is kit,and I get(buy) a PCB with parts and manual instruction,my job is only conclude.
This kit is in circulation but ten years.
I wanted to build later in bridge mode,but speaker shold be 8 ohm's,
Old 6th November 2009, 02:41 PM   #9
Did it Himself
Sounds like a good project for you then, although I think 1/2 watt for R16 and R17 is far too small. Maybe it is a mistake and it should say 2W.
Old 6th November 2009, 06:30 PM   #10
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Yours experience?
This circuit is one of my prefer topology for Class AB mode (20-30mA idle current through the output devices). If there are 10-15 mA idle current for T1 and 30 - 50mA for T2, so as additional jFET input buffer and high quality capacitors/transformers, then such an amplifier is very hard to beat (except nessecary concepts with pure class A in the output).
There are also some commercial amplifiers, that have inside this topology, e. g. the no longer exist U.K. brand "Nytech", model No CA202 (CA-202), have a look to http://images.deep-resonance.net/image/85.jpg
http://i36.tinypic.com/2chxelx.jpg
and the pdf file:
Your opinion about this schematics?Hide this!Advertise here!
your opinion please motor_maniac18 Subwoofers 2 5th October 2005 12:59 AM
Your opinion, please croccodillo Tubes / Valves 2 14th September 2005 03:40 PM
opinion oldbar Multi-Way 11 25th May 2005 05:25 AM
Opinion on a Mid Madmike2 Multi-Way 1 9th May 2005 03:24 AM
I need your opinion.. Richard Moon Everything Else 1 11th January 2004 06:14 AM
Copyright ©1999-2017 diyAudio
