If you want to check the sound of germanium output devices, I would not try to perform a diy project. You buy at best an old and used exemplare of the Braun amplifier, model "CSV 10" (CSV10) years of production: 1963-1966Thank you, friend!
Germanium amplifier because we want to hear what the sound is such an amplifier.
Those familiar sound claim to the sound of the amplifier with different Si transistors?
http://www.achtgrad.de/archiv/fotos/braun_csv_gr.jpg
http://wegavision.pytalhost.com/jahrbuch2/Verst%E4rker/Braun_CSV10.jpg
or "CSV 250" (CSV250) from the year 1965
http://telefunken.te.funpic.de/jahrbuch3/Verst%E4rker/Braun%20CSV250.jpg
Braun CSV 250 das kleine Topm. gut erhalten für Bastler - eBay.ch (endet 25.10.09 19:40:40 MEZ)
Thank you richie00boy !
tiefbassuebertr ..I like to build amp,not to buy,but thank you for help!
If you order the schematics of the mentioned models, you get some inspiration to your own project
you get the schematics about
Kontakt: Schaltungsdienst Lange oHG
yes, because there are the widest schematic range over the world, but only for pay and nothing for free.Frend, I can't find schematic in that site.
If you can,find for me same scheme, than put this adress in my topic in this forum.
Thank you!
In the meantime I have start follow threads, where you will find even a lot of schematics from germanium and silicon Solid State amps arround the early days (between 1960 and 1970):
http://www.diyaudio.com/forums/soli...id-state-audio-amplifier-components-want.html
http://www.diyaudio.com/forums/soli...-models-quasi-complementary-power-output.html
and two additional threads from other member:
http://www.diyaudio.com/forums/solid-state/162142-tip3055-2n3055-based-power-amps-3.html
http://www.diyaudio.com/forums/soli...st-complementary-ab-bipolar-amplifiers-5.html
http://www.diyaudio.com/forums/parts/167680-vintage-transistors.html
- Your opinion about this schematics?
