Old 13th April 2010, 01:10 PM   #71
Elvee is offline Elvee  Belgium
Elvee's Avatar
I should have made clear that I was looking for very high voltage devices. In this respect, the SJEP170R550 from Semisouth is marginally better than the ST.
For the small to medium power bipolar, I was trying to find something similar to the BUX87, but higher voltage, and more suitable for linear operation.
Thanks for the pointers anyway, the SiC looks promising.
Old 13th April 2010, 04:15 PM   #72
tiefbassuebertr's Avatar
I recall to some BjT high voltage types from Shindengen but on the currently website I don't find such types:
Home | SHINDENGEN ELECTRIC MFG.CO.,LTD
perhaps there you will find appropriate types:
Description TRANSISTOR, TRANSISTOR Datasheet search, TRANSISTOR datasheet, TRANSISTOR datasheets, TRANSISTOR data sheets - ALLDATASHEET.COM
the follow is made prefer for switching application (HFX Series):
http://www.datasheetcatalog.org/data...gen/mXrwvs.pdf
but the question is whether it is only suitable for switch applications
There are some other HV BjTs, but except the MJ16018 MJ16018 pdf, MJ16018 description, MJ16018 datasheets, MJ16018 view ::: ALLDATASHEET :::
I don't know types for linear applications:
2SC3996 pdf, 2SC3996 description, 2SC3996 datasheets, 2SC3996 view ::: ALLDATASHEET :::
BUH1215 Datasheet pdf - HIGH VOLTAGE FAST-SWITCHING NPN POWER TRANSISTOR - SGS Thomson Microelectronics
BUY71 pdf, BUY71 description, BUY71 datasheets, BUY71 view ::: ALLDATASHEET :::
Old 14th April 2010, 07:54 AM   #73
by post #32 about
Successors for V-FET SONY-Yamaha-TOKIN 2SJ28, 2SJ18/2SK60, 2SJ26/2SK76 and 2SK180
there are informations about various patents concerning SIT's - perhaps also of interest here
Old 11th May 2011, 10:43 AM   #74
Originally Posted by Elvee View Post
This my final (lab) version, including a latching protection.
I am currently adapting the topology for very high voltage output (>1KVpp).
could you perform a stability test so as an audible test already?
Old 12th May 2011, 05:00 PM   #75
Elvee's Avatar
Here is a plot of the loop gain:
Old 27th July 2012, 08:10 PM   #76
here a solution for a passive phase reverse stage (i. e. with interstage transformer resp. driver transformer instead a totem pole common emitter or emitter follower topology):
F6 Amplifier
Old 30th July 2012, 07:55 PM   #77
Elvee's Avatar
F6 Amplifier
It takes me back 40yrs: I remember building such an amplifier, transformer-less output based on AD149's, and at the time I found the sound amazingly good...
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Dirty Cheap Vintage Pot Fix - Your Opinion Please LinuksGuru Tubes / Valves 1 5th February 2009 06:57 PM
Noob cheap and dirty speaker measurements neil_kaye Multi-Way 4 14th April 2008 05:30 AM
OTL, quick `n dirty Fuling Tubes / Valves 4 27th December 2004 07:44 AM
cheap and dirty sub hacknet Solid State 20 19th December 2002 04:14 PM
Copyright ©1999-2013 diyAudio
