It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!!
Old 21st November 2009, 02:07 PM   #11
Pano is offline Pano  United States
Pano's Avatar
Quite a beast! Seems to do what you wanted. =) I like the part about injecting noise into power lines. That would be very handy.
As good as it is on difficult loads, wonder how it would do driving electrostatic panels? Should do well.
Take the Speaker Voltage Test!
Old 21st November 2009, 04:34 PM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
It should do well, but in this version, a transformer would still be necessary.
But it would also be possible to "unfold" the cascode, in order to use only high voltage/N devices in the driver and output stages. This should make a direct drive possible.
Old 21st November 2009, 07:01 PM   #13
event horizon is offline event horizon  England
event horizon's Avatar
Thumbs up I like it
I have been looking round the net for designs that use all N channel mosfets & i have to say that this must be one of the most innovative that i have seen
I just love the way it can swing nearly rail to rail by the simple addition of a capacitor (2.2uf), as you know you'd normally need a higher supply voltage on the positive side.
Any idea on the damping factor? I should imagine it should be pretty high or certainly could be made to be so. With no output inductor it should it should be fairly high to high frequencies to.
Very interesting, you have gotten me thinking
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 21st November 2009, 08:21 PM   #14
Elvee's Avatar
Congratulations, event horizon, you were smart enough to catch the main innovation of the design!
This version has an output impedance of ~100millohm.
At relatively low frequencies at least; at higher frequencies, you can have an idea of the behaviour by looking at the load-dumping and low-impedance tests.
But as you rightly conjecture, it is indeed possible to improve this factor, and I will also describe a more elaborate version doing about 20dB better on this point.
Old 23rd November 2009, 03:53 PM   #15
Elvee's Avatar
Next variant is equipped with an auto-bias servo circuit.
This inclusion is easy and natural, thanks to the already present threshold shifter.
Most of the circuit and characteristics remain unchanged, one of the source resistors can be eliminated.
Iq is set by the ratio of R18 to R19.
Old 23rd November 2009, 04:21 PM   #16
kevinkr's Avatar
This is a very interesting design, and I really liked the picture of the glowing screw sitting... umm, err, sitting a couple of cm above a very flammable carpet.. Could have been quite exciting Ought to exercise a little more caution...
Could you please post a full size schematic from the sym as the ones presented do not render properly on any of several PCs I have access to. (Windows & Linux)
I'm thinking this design would be near ideal for use as the PA in an active AC line conditioner/source using a toroid as a step up transformer. Target power would be a couple of hundred watts at 60Hz.. The fact that this thing appears to be indestructible makes it ideal for driving all manner of loads reflected back through the output transformer.
You might want to consider offering a PCB for this design as I suspect (naively hope) that there would be some interest here?
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd November 2009, 05:22 PM   #17
Elvee's Avatar
Don't worry: it's a melamine coated MDF board. No risk.
I'll try.
A word of caution: robust is not synonymous with indestructible, and if you grossly exceed the dissipation or SOA limits of the output devices, you will fry them (it happened to me).
But it is true that this amplifier is capable of driving loads that nobody in his right mind would dare putting even close to the output terminals of a "normal" amplifier. And it drives them with insane signals, at high power and high frequency.
Also note that the input current is large, and the input impedance is low, compared to a regular audio amplifier. In 50 ohm systems, this is no problem.
And for 200W, you'd need to parallel a number of devices.
I will also describe a number of variants, including one with a special protection circuit
Sorry, I don't do PCBs
Old 3rd December 2009, 07:53 AM   #18
Elvee's Avatar
Default Lower distortion
The next variant has a higher loop gain.
This results in a higher feedback factor, and a reduced distortion: the linearity is now around 5 ppm at near-full power (0.0005% dist.)
Other characteristics remain practically unchanged.
Old 3rd December 2009, 08:12 PM   #19
AKSA is offline AKSA  Australia
Very impressive work, Elvee, thank you! Can you do something with 50V rails?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 4th December 2009, 06:58 AM   #20
east electronics is offline east electronics  Greece
east electronics's Avatar
Default a bit of ....off topic
is there anyone that can answer me a question regarding induction heating as seen in the example of the OP ????? please ????
the question is:
if a circuit like that consuming so litle power can make a screw actually glow why is there no one so far designed some device that has 4-5 similar coils and 4-5 similar screw or other metal parts, that your home water supply runs through this device cold at the input and boiling hot at the output ?????
i have seen various applications on the internet but nothing like that ...
is there any darwbacks ???? or something i ve missed ???
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
It's cheap, it's N, it's dirty, it's.... The CIRCLOMOS!!!Hide this!Advertise here!
Dirty Cheap Vintage Pot Fix - Your Opinion Please LinuksGuru Tubes / Valves 1 5th February 2009 06:57 PM
Noob cheap and dirty speaker measurements neil_kaye Multi-Way 4 14th April 2008 05:30 AM
OTL, quick `n dirty Fuling Tubes / Valves 4 27th December 2004 07:44 AM
cheap and dirty sub hacknet Solid State 20 19th December 2002 04:14 PM
Copyright ©1999-2017 diyAudio
