Hello,
I am currently designing a class-A power amplifier. I was looking to mount the diodes, that I plan to use in the current source that will set the output stage bias, on the heatsink, in order to thermally compensate the BJT's. I am looking for suggestions as to how to physically mount the diodes on the heatsink. Thanks! ig |
#2 |
The old solution was to use diodes in a metal can and a small metal strap clamp. The old SWTPC Tiger amps did this. You could pot the diodes in a small piece of brass tubing and do the same thing using thermally conductive epoxy. You could wrap the diode in a piece of Sil-Pad type material and use a flat spring clamp. You could also find a suitable diode in a TO-220 case and mount it in the conventional way. You could use one junction of a small metal body transistor.
I used to be an audiophool like you but then I took an arrow to the knee. |
#3 |
Or just connect a TO-126 transistor such as a cheap BD139 as a diode (c-B) and use that.
#4 |
#5 |
When using a transistor as a diode you generally connect the collector to the base.
#6 |
Well now, GK, I am unclear on your suggestion now.
Are you saying to connect using the collector AND base as a diode? (as implied in post #3) Or are you suggesting they connect the base TO the collector, leaving the B-E junction as the diode? (as implied in post #5, which was the suggestion syn08 made) In other words, do you want to say connect the collector to the base, or do you want to say connect to collector and base? |
#7 |
Yes GK is saying to connect the base to the collector and use the BE junction as the diode.
#8 |
Yes, sorry, by “(C-B)” I meant collector connected to base. I just figured everyone would know that already
#9 |
Thanks alot guys, it didn't even occur to me to use a transistor junction, duh!
That will greatly facilitate heatsink mounting. ig |
#10 |
In addition to the above, I assume the best transistor to use as a diode would be the same model as the output transistor to bias, as they will exhibit the same temperature coefficient. Would that just be splitting hair, or would any cheaper transistor behave close enough to be almost just as good?
And when it comes to setting the current through the "diode transistors", I guess the Ic v.s. Vbe plot in the spec sheet is what I should look at to make the initial prediction to determine Vbe voltage drop right? And I would assume the former is the reason why the collector should be tied to the base in this situation. Thanks, ig |
| small-signal (small-power) fast switching complementary transistors | Lola Luna | Solid State | 3 | 8th April 2010 07:51 PM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| Mounting a Heatsink | Bigman | Chip Amps | 8 | 13th December 2007 02:00 PM |
| Suggestion of good bridge diode for A2 | Alvin | Pass Labs | 3 | 28th May 2005 12:35 PM |
| Heatsink mounting. | JoeBob | Solid State | 3 | 21st January 2002 02:51 AM |
| Page generated in 0.09841 seconds (76.25% PHP - 23.75% MySQL) with 11 queries |
