As a simple project I decided to so a simple preamp using high speed unity gain opamps as line drivers. One channel seems to work fine but on the other one there is a DC offset of about +7V on the +Vin pin, Im sure the wiring is correct, can anyone think of what the problem might be? Could it be that the chip is somehow damaged?
Any suggestions greatly appreciated jnxw2 |
#2 | ||
If not... Quote:
Cheers
Jorge |
#3 |
Sorry my mistake for not being clear enough, the DC Offset is on the non inverting input.
Also dont know if it is important or not but it is a current feedback opamp jnxw2 |
#4 | |
Jorge |
#5 |
Thats right, the inverting input is at 0V as is output.
jnxw2 |
#7 |
Sorry...bad news...the Ic is dead!
It will rest in peace!!! Amen!
Jorge |
#8 |
Not to spoil your party, but how do you rate the chance that the new opamp you put in will also die untimely? Where's the f<]u*#c*#k@i^%n@!g schematic??
Jan Didden |
#9 |
Yeah i was kind of coming to that conclusion aswell
![]() Here is the diagram. jnxw2 |
#10 |
You connected the - input to ground???
| Cancelling DC Offset in a bipolar Opamp | ygg-it | Chip Amps | 16 | 5th May 2008 04:47 PM |
| Two Questions, Reading leads on Opamp and Offset Trim | pjpoes | Parts | 10 | 28th December 2006 09:06 PM |
| Single supply opamp - unequal rail voltage and opamp selection | Hans L | Parts | 8 | 19th February 2006 02:15 PM |
| Opamp/DC-Offset Problem (Help!) | MWP | Chip Amps | 9 | 9th September 2004 04:13 AM |
| opamp replacement & dc offset trouble | Raj1 | Digital Source | 14 | 6th December 2003 11:56 AM |
| Page generated in 0.12494 seconds (78.26% PHP - 21.74% MySQL) with 11 queries |
