My implementation of the Cordell Distortion Analyser
Old 1st November 2009, 08:32 AM   #11
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Great job, Patrick!
Thanks for the info on the case,
jd
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 1st November 2009, 12:46 PM   #12
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
kudos, patrick
great job!
other than balanced, did you make other enhancements?
mlloyd1
Old 1st November 2009, 01:42 PM   #13
EUVL is offline EUVL  Europe
Only changed one or two opamps to LM4562, etc.
Patrick
Old 1st November 2009, 08:55 PM   #14
Dave is offline Dave  New Zealand
This is probably a silly question but where can I find the schematics?
DIY DAC, 24/192 inputs, fully balanced
http://www.diyaudio.com/forums/showt...hreadid=122078
Old 1st November 2009, 10:35 PM   #15
jcx is offline jcx  United States
I wouldn't bother today - add a few filters to supress fundamental and use a sound card - indirect IMD measurement resolution can reach way below human hearing noise floor with averaging
the ESI Juli@ is ~US$120 and has great resolution and low distortion by itself
Old 1st November 2009, 11:44 PM   #16
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
JCX, is the problem with a sound card not the fact that the bandwidth is limited to c. 22kHz? How do you do a wide bandwidth measurement (e.g. 80Khz like the AP)? Another thing is frequency response (although not covered by Bob's instrument) - sound cards do a great job of measuring 5Hz to 22KHz - but after that what do you do?
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 2nd November 2009, 12:25 AM   #17
Conrad Hoffman is offline Conrad Hoffman  United States
Great job- mine isn't as pretty!
I built my Cordell analyzer over a period of a couple years, starting right after the Audio magazine article came out. Etched my own boards from the published patterns. It's a super instrument and I wouldn't trade it for the world. Sound cards are great as far as they go, but bandwidth, calibration and certainty of the result are all issues. You can get wildly different results depending on sample rates and bit depths. The only way I'm sure of what my sound card is doing is to compare it with a conventional THD analyzer. Also, at least with my Emu, the ADC quality is great, but the DAC snr is unimpressive. One would never mistake it for a high quality analog signal generator. The noise isn't obvious in a spectral plot, but sticks out like a sore thumb on a scope.
The only downside to building a Cordell these days is the expense and difficulty of building up the switches. Sometime I'll post a photo of mine. It's been trouble free and the floor is about 0.0002% midband.
Best,
Conrad
I may be barking up the wrong tree, but at least I'm barking!
Old 2nd November 2009, 01:02 AM   #18
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Bravo, Patrick
Old 2nd November 2009, 03:00 AM   #19
I appreciate fine analog circuitry and good dedicated function test equipment as much as anyone - but the lazy cheapskate in me can't ignore the possibilities of today's good&cheap digital hardware
the ESI Juli@ has up to 192K sample rate so it can make measurements comparable to the classic 80 KHz BW audio distortion analyzers
with a few active filter circuits to cut the fundamentals of the test signals and boost the error signal you can resolve with very good accuracy with better soundcards - spurious free dynamic range before the added filters can be ~100 dB, indirect measurement tricks with two channels generating IMD test tones and added gain/filtering can allow resolution of nonlinear test circuit behavior to exceed 160 dB
Free SciLab or other processing software can extract anything you can write the equations for from the .wav files
Old 2nd November 2009, 03:55 AM   #20
The link to Bob's article :
http://www.cordellaudio.com/papers/thd_analyzer.pdf
Patrick
My implementation of the Cordell Distortion AnalyserHide this!Advertise here!
Distortion analyser circuit steevo Solid State 12 21st July 2008 01:42 AM
IM Distortion Analyser Alain Dupont Parts 2 6th January 2005 02:48 AM
Usable distortion analyser for Pre-/Amps MichaelB Solid State 22 1st February 2004 12:39 PM
HP334A Distortion Analyser Netlist Swap Meet 1 14th October 2003 10:33 PM
HP333A Distortion Analyser Netlist Equipment & Tools 12 13th October 2003 09:40 PM
Copyright ©1999-2017 diyAudio
