Old 16th November 2009, 05:13 AM   #41
Pano is offline Pano  United States
Pano's Avatar
Yeah, but it sounds so good. Just something about a DC coupled amp.
OK, back on topic, sorry.
Old 16th November 2009, 05:29 AM   #42
pheonix358's Avatar
What we don't understand is called magic.
Old 17th November 2009, 10:36 AM   #43
Ok,
I've been through my back issues of Silicon Chip.
The July 1996 issue has a 3-band parametric equaliser. It's a very basic circuit, all 3 bands are standard boost/cut variable Q (bandpass). It wouldn't be very suitable for loudness compensation, where we require a relatively shallow LF boost and then a sharper cut for excursion control.
But as I was putting the magazines back on the shelf, I glanced at the cover of the December 1997 issue. "Loudness control for car hi-fi." It appears to be intended to do almost exactly what I have in mind. I'll summarise the article later.
Old 17th November 2009, 11:28 AM   #44
pheonix358's Avatar
Originally Posted by Don Hills View Post
Ok,
Have a look , if my memory serves me well, at the 4th section. The parametric was three stage as you said, there was a fourth stage.
Terry
Old 18th November 2009, 12:41 AM   #45
Terry
Nope, definitely just 3 bandpass stages. But like you, I'm sure I've seen a circuit for a parametric with a shelving filter at the LF end somewhere.
I'll take a look through the yearly indexes and see if there were any others.
According to the SC Web site, there was a subwoofer controller with parametric EQ in the December 1995 issue. It was updated in 2007:
Silicon Chip Online - Subwoofer Controller
Maybe that was it?
I've now looked at the loudness control from the December 1997 issue.
It's not suitable. The LF boost starts too far up the frequency range, and the amount of boost actually starts to reduce again as the volume setting nears minimum. It also boosts the treble as well as the bass, which I have always found unnatural. The response curves were apparently arrived at by experiment, which likely means the curves were chosen to suit a typical car stereo rather than a home environment.
Old 19th February 2010, 09:19 AM   #46
davygrvy's Avatar
Originally Posted by jamikl View Post
I guess I am looking for a circuit to reduce boost with increasing volume but operated off the volume control so that two separate controls are not needed. This is to reduce xmax at high volumes. Thanks for any help, negative or positive.
jamikl
See Reading driver displacement with radar!
Why not monitor actual displacement and use that as a key to limit input signal to the LF driver? No preamp mods required.
Think out of the box
Old 5th March 2010, 10:28 AM   #47
Artie is offline Artie  United States
What is needed is a progressive bass boost/cut control linked to the volume control, along with a gain setting control that lets you calibrate your system to the standard.
Sorry to revive this old thread, but I found this while doing a search for "subsonic filters".
Isn't the above exactly what Yamaha was doing with their older recievers and amps from the 70's and 80's? They all had the variable loudness control that worked in conjunction with the volume control. One could simply download an old Yammy schematic and copy their loudness technique.
Old 5th March 2010, 09:34 PM   #48
I'll take a look, thanks. I even have an old Yamaha receiver awaiting restoration, I'll check if it has the control. (It's so old it has tiny vacuum tubes (nuvistor 6CW4) in the RF stages of the FM tuner.)
Old 5th March 2010, 11:23 PM   #49
AJinFLA is offline AJinFLA  United States
Banned
I recall the Yamaha's with the variable loudness controls, but I don't think they were tied to the volume.
The Chase that I mentioned previously, did just that.
cheers,
AJ
Old 6th March 2010, 11:22 PM   #50
Key is offline Key  United States
I tried this out last night and it seems to work. It works for increasing and decreasing and the first volume is for calibration.
Tone Control with Loudness ? thoronx Solid State 43 2nd March 2011 05:26 AM
Loudness Control Calc - Help Please LinuksGuru Tubes / Valves 0 14th December 2008 04:43 PM
Looking for info on loudness control normanjr Tubes / Valves 5 26th September 2006 05:43 PM
loudness control maylar Solid State 6 28th March 2004 05:12 AM
Page generated in 0.11364 seconds (84.39% PHP - 15.61% MySQL) with 11 queries
