simple Amplifier?
simple Amplifier?
Old 21st May 2003, 07:43 AM   #1
technics is offline technics  Germany
Default simple Amplifier?
This is my first posting in here - so be not too strict with me
I just found this schematics on the web.
Can anyone tell me, if it's worth a try?
I just want to build a really simple amplifier. It don´t have to be with shortening protection or anything like that or dc-protection for the speakers.
If you have any other good and simle circuit which runs on +/-45V let me know, please
Old 21st May 2003, 10:12 AM   #2
djk is offline djk
R.I.P
djk's Avatar
A couple of comments:
Sneak another 1N4007 in series with the other two so you end up with a string of three diodes.
Add a 100pF cap from B to C on the TIP41, that may be too big, but better safe than sorry.
Heatsink the outputs real well with either grease and mica washers, or rubber insulator pads.
The 27K on the input would be better if it was 22K, less chance for DC off-set.
Lower the 1K5 on the input transisors to 1K.
And very important: you must add a 0.1F cap in series with 10 ohms and then put this combination directly across the speaker out terminals.
I expect this will do 75W at 8 ohms. I wouldn't run it at 4 ohms without reducing the supply voltages.
Old 21st May 2003, 10:45 AM   #3
Just for me as a newbie, why is this so important?
What about using BD249/250 for the TIP142/147? Seems they can handle more current and are also Darlingtons...
Old 21st May 2003, 07:41 PM   #4
hugobross is offline hugobross  Europe
so this is what the amp looks like (after djk's suggestions):
best regards,
HB.
Old 21st May 2003, 07:59 PM   #5
JDeV is offline JDeV  United Kingdom
Default Re: simple Amplifier?
Did you look at this forum?
http://www.diyaudio.com/forums/forum...php?forumid=40
Example of very easy/simple circuit which you will find there, and can work from 45-0-45 (with LM3875 for example - which you can get as free sample
Old 21st May 2003, 07:59 PM   #6
I would suggest something like this:
any comments welcome,
HB.
EDIT: zener is 12V one
Old 22nd May 2003, 06:27 PM   #7
Default Re: Re: simple Amplifier?
Thanks for this circuit - maybe Ill give it a try. But occuring to the datasheet it will "just" have 56 Watts on 8 Ohm which isnt very much on +/-45V...
Id like minimum of about double this value (say 100Watts continous power on 8 Ohm), but capable of powering 4 Ohm with approx. 200Watts. So that bridging on 8 Ohm is possible.
I got here 4 power supplies with each delivers continous 350VA by trafo and enough caps to get stable power.
So I could build 4 identical amps and bridge each two of them to get 2 bridged channels.
Or I could bridge each two of the trafos and build 2 amps with each running at +/-90V...
Old 22nd May 2003, 06:30 PM   #8
megajocke is offline megajocke  Sweden
megajocke's Avatar
I think a forward-biased LED would be better than a 12V zener, or you'll lose lot of drive in the positive direction, the output would probably clip at already 30V or something like that... the resistor values will have to be changed in that case too. I also think a LED is less noisy than a zener.
Old 22nd May 2003, 06:39 PM   #9
elizard is offline elizard  Canada
Send a message via MSN to elizard
lm3875 cannot run off of 45-0-45 ..
that's 90V, its max being 84V, that's a little too much
i wouldn't recommend more than 40-0-40 ..
just thought i'd clear that up
Old 23rd May 2003, 10:06 AM   #10
djk is offline djk
R.I.P
djk's Avatar
"Just for me as a newbie, why is this so important?(0.1F+10R)"
If the amp doesn't 'see' a load at high frequency it can oscillate and blow up.
"What about using BD249/250 for the TIP142/147? Seems they can handle more current and are also Darlingtons..."
The TIP142/147 are plastic and rated at 125W at 25*C, in a real amplifier I wouldn't expect to see them run harder than 60W for the pair.
If you could find some 200W plastic darlingtons I wouldn't run the pair harder than 100W, and be sure and look at the secondary breakdown curves too. The TIPs start to fold back at 30V, even though they are a 100V rated part.
And when I say 60W or 100W I mean into the lowest impedance the amp will be expected to drive. If you make the voltage high enough to do 100W/8R you will not be able to drive 4R with only one pair of outputs. If you set it up to do 100W/4R, expect to see about 60W/8R
" but capable of powering 4 Ohm with approx. 200Watts. So that bridging on 8 Ohm is possible."
"Or I could bridge each two of the trafos and build 2 amps with each running at +/-90V..."
I would pick the 90V option, less hassle than bridging. If you have a good heatsink and will only be diving 400W/8 you can get away with only three pair of MJ21193/21194 plus driver transistors. If you expect to drive 600W/4R off the same 90V you will need five pair, 1000W/2R you will need eight pair.
If you want to use plastic, the MJL21193/21194 have the same die in a plastic case, but you will need to use TWICE as many to get the same reliability. Or you could do a tiered power supply with 45V and 90V rails and fewer outputs.
simple Amplifier?Hide this!Advertise here!
Simple Hi-end 845 amplifier audiodesign Tubes / Valves 57 2nd January 2009 07:09 PM
Simple amplifier hobbit Solid State 15 27th January 2008 06:30 AM
REALLY simple amplifier? CalcProgrammer1 Solid State 19 28th November 2007 10:37 PM
simple amplifier bigspeakers Chip Amps 4 23rd June 2006 12:34 PM
need a simple amplifier DrSplodge Everything Else 12 28th July 2004 06:49 AM
