Closed Thread
Old 2nd November 2009, 08:16 PM   #51
R.I.P.
The use of N channels in both sides of the schematic is a TYPO - he may be good but he can't defeat the laws of physics.
Regards, Allen (Vacuum State)
Old 2nd November 2009, 08:36 PM   #52
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
hi Greg Erskine,
I did everything described in three articles, there are two.
First How to 3D Eagle Basic installation of Eagle, Eagle 3D and Pov Ray. There are some forms package, they will come in handy when you do not know.
Second As 3D Eagle again Faultfinding
Old 2nd November 2009, 08:57 PM   #53
anatech is offline anatech  Canada
anatech's Avatar
Hi Federmann,
I tried using Google translation with your web site, and ended up with a spinning head as a result.
When you post, would you please refer to documents and information in English? Most of your work is somewhat lost on me due to the language barrier. I fear most of our membership may be in a similar position - unable to understand what you are doing.
One part on your site refers to a transistor type. I guess it's a power mosfet made up from many smaller transistors inside. Can you elaborate please? My experience with current mosfets is that no source resistor = blown amplifier.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 2nd November 2009, 09:01 PM   #54
PMA is offline PMA  Europe
PMA's Avatar
We should ask if he has built the amplifier shown.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 2nd November 2009, 09:40 PM   #55
Greg Erskine's Avatar
Originally Posted by Federmann View Post
hi Greg Erskine,
Hi Federmann,
Thanks for the info. I have looked at your links and done my best to follow by looking at the pictures. I was wondering if you have used this method to generate you ini file. It creates a flythru rather than just rotating the 3D model.
en:eagle3d:documentation [www.matwei.de]
regards
Greg Erskine
Old 3rd November 2009, 01:45 AM   #56
anatech's Avatar
Hi Pavel,
Well, it looks like construction has begun. I didn't see anything looking done though. An English version on his web site would help there, but I'm guessing you know much more than most of us here.
-Chris
Old 3rd November 2009, 02:29 AM   #57
Ultima Thule's Avatar
Besides the idea of putting N-ch devices in the lower part it's also quite interesting way how they are implemented as we know FETs have an intrinsic diode... *BOOM*
I could understand under time pressure if one didn't have a P-ch handy in the library to get the D and S right for P-ch one have to put the N-ch upside down to get the layout correct, but the designer with forty years of experience clearly told us he wanted to use N-ch makes me wonder if this all is a hoax, time is the truth teller....
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Old 3rd November 2009, 03:32 PM   #58
cbdb is offline cbdb  Canada
Only JFETs
Old 3rd November 2009, 03:49 PM   #59
PMA's Avatar
Originally Posted by cbdb View Post
Only JFETs
Wrong.
Old 3rd November 2009, 05:37 PM   #60
Federmann's Avatar
Closed Thread
UcD like topology amp. Bender.ru Class D 232 21st March 2012 03:55 AM
Anyone seen this amp topology before? BlackUnikorn Tubes / Valves 14 6th August 2008 08:51 PM
Page generated in 0.09389 seconds (82.58% PHP - 17.42% MySQL) with 11 queries
