Closed Thread
Old 7th November 2009, 09:48 AM   #181
BV is online now BV  Slovakia
Could also show a simulation with only gate voltage of both IRFP240 and IRFP9240 and output voltage of the amplifier, thank you!
Simulators do not make mistakes
Only peoples, who used them without real background.
Old 7th November 2009, 09:48 AM   #182
We are not curious about your simulations, but about practical results...do not say, that you have not time to try it...something different discourage to you try it, probably you do not like firework...
Old 7th November 2009, 09:59 AM   #183
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
Add emitorových resistance 0.22Ω. I see that the effect of temperature on the reduction of current is smaller!
Emitter resistors suppress thermal effects RDS and highlight temperature effects VGS!
Old 7th November 2009, 10:02 AM   #184
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by Lumba Ogir View Post
Michael,
you are apparently filled with a genuine sense of profound excitement for an underdeveloped idea, based on circulating marginated stereotype templates of random concepts, exacerbated by poorly substantiated technical suppositions and a neglectful, fragmentary cross-functional sequence analysis, lacking applicative-type structure norms and a reliable symptomatic long-term specificity, obscuring the outcome. You should, however, show your overwhelming but unfounded admiration in a calm and collected manner in oder to avoid finding yourself in the cumbersome situation of being threatened with a stiff bin time sentence.
Nice and decent post, perfect sense of humour. Thank you, Lumba. It could not be said better.
Pavel
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 7th November 2009, 10:05 AM   #185
Is it your practical experience ? Some pics from scope ?
Old 7th November 2009, 10:14 AM   #186
Federmann's Avatar
Add emitorových resistance 0.6Ω. Switched zener diodes. Emitter resistors suppress thermal effects RDS and highlight temperature effects VGS!
Negative branch has no temperature dependence. Positive branch at a higher temperature, more current flows! Now there is an explosion!
Old 7th November 2009, 10:26 AM   #187
PMA's Avatar
I give up this thread.
Old 7th November 2009, 10:42 AM   #188
Federmann's Avatar
I can increase the emitter resistors to explode the negative branch.
I can generalize:
1) RE = 0Ω, the biggest positive influence of the temperature dependence RDS.
2) RE ≥ RDS, the suppression of the positive temperature dependence of the RDS and highlight the negative temperature dependence of VGS.
3) RE> RDS, negative temperature dependence VGS = unstable condition! Stability must be addressed else means.
Old 7th November 2009, 10:50 AM   #189
PMA's Avatar
3) RE> RDS, převládnutí negative temperature dependence VGS = unstable condition! Stability must be addressed else means.
Check your translator from Czech to English, you are mixing Czech and English language together.
Old 7th November 2009, 10:54 AM   #190
Ultima Thule's Avatar
I can generalize:
Federmann,
let me tell you, the RDSon tempco effect is only valid when you are saturating the MOSFET, then you have Negative tempco, this works ONLY for Class-D / Switch Mode Power Supplies!
In the linear mode the RDSon has NO EFFECT on the tempco stability!
Cheers Michael
"If transistors are blueberries and FETs are strawberries, then tubes must be.. pears"
Michael 29th January 2010
Closed Thread
UcD like topology amp. Bender.ru Class D 217 Yesterday 04:32 PM
Anyone seen this amp topology before? BlackUnikorn Tubes / Valves 14 6th August 2008 09:51 PM
Page generated in 0.11433 seconds (82.04% PHP - 17.96% MySQL) with 11 queries
