Closed Thread
Old 6th November 2009, 07:55 PM   #161
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by BV View Post
Overcurrent "protection" is one mistake, showed frequency compensation second.. It will be for sure power oscilator (for short time before explosion), slow output stage and "fast" input and VAS without local compensation closed in global NFB..Unrealistic. We have to wait for measured results.
Yes, BV, we are still talking about the worst mistakes. Also, absence of the MOSFET driver circuit is a big issue.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 6th November 2009, 08:07 PM   #162
Juergen Knoop's Avatar
thank you Federman for posting the picture and telling us about the current status of your project.
Old 6th November 2009, 08:32 PM   #163
Juergen
One positive thing is that if you build this thing and turn it on it will be completely dark.
You know ladies like candle lights.
Sorry for being of topic, but here is a link.
Cheers
Old 6th November 2009, 09:06 PM   #164
Stinius,
OT:
ouuh, but they certainly don't like campfires indoors!
Back to topic...I don't care very much about simulated circuits and virtual projects. If Federmann presents something readily build, I would be curious about it and would happily add my two cents why it works or fails.
Old 6th November 2009, 09:09 PM   #165
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
Originally Posted by megajocke View Post
Here is why it will not work well without source resistors. Let's look at Vgs = 4.5V and Vds > 10V. In that case, the drain current is:
For temperature = 25 Celsius, it is Ids = 0.6A.
For temperature = 150 Celsius, it is Ids = 25A.
That is not a reduction in current with increased temperature!
All the parallelled transistors have the same Vgs so the hottest one will work harder than the others. Drawing a load line and pointing at it is nonsense. It is current sharing that is the problem, nothing to do with the load line.
However, the BUZ9** transistors you mention on your page do not have this problem. They can be parallelled just fine without resistors.
Transistors are next to each other, it is not possible that the first had a temperature of 25°C and the second 150°C. Forget the positive temperature coefficient RDS. I do not recommend temperatures above 80°C. Chips are selected for BUZ what the problem is to choose four transistors? Why look for problems where not?
Nice night
Old 6th November 2009, 09:14 PM   #166
PMA's Avatar
Juergen,
simulation, if properly used, is a great help and saves lot of time to a designer. However, its is the aid, not the final goal. Every professional company use simulators, please read Scott Wurcer's comment on that. But, if let in hands of pure theorists with no practical background, simulation may be misleading. Also, it does not substitute lack of professional background.
So please be careful before you disapprove simulation, rather consider the content.
Old 6th November 2009, 09:19 PM   #167
PMA's Avatar
Nice night
No two IRF240 or IRF9240 have same charecteristics!!!!!
You consider one datasheet plot example as to be same for all devices, and this is a huge lack of understanding. The difference of characteristics leads to different current load to paralleled devices and therefore to different chip temperature. These things happen instantly and you do not see them in plots you are permanently displaying. Why do not you study publications on breakdown that danhard has linked here??
Old 6th November 2009, 09:34 PM   #168
Federmann's Avatar
Once again, good night
Old 6th November 2009, 09:39 PM   #169
PMA's Avatar
Federmann, please take a soldering iron in your hand, and build a working sample. Then you can defend your circuit ideas.
Old 6th November 2009, 09:44 PM   #170
I am wailing, Federmann....try to make simply experiment: setup Vgs at 100mA Ids with IRFP240 and let it be. After a few seconds current will rise up to ampere region and after while device will be in silicon heaven...Now do the same with 2SK134 ( lateral type ) - here is Ids quite stable, or little fall with rising of temperature....It is reason, for what we can connect lateral ones in parallel, because they have in this working point zero Tc, but vertical ones not....Is not easy to understand ?
Closed Thread
UcD like topology amp. Bender.ru Class D 222 Yesterday 03:49 PM
Anyone seen this amp topology before? BlackUnikorn Tubes / Valves 14 6th August 2008 09:51 PM
Page generated in 0.12713 seconds (78.06% PHP - 21.94% MySQL) with 11 queries
