Closed Thread
Old 6th November 2009, 04:05 PM   #151
SOAR IRFP240/9240 by 90V : circa 3,5A/10 msec. By simulation : 30A/5 = 6A....
Old 6th November 2009, 05:53 PM   #152
Federmann's Avatar
Send a message via ICQ to Federmann Send a message via Skype™ to Federmann
You're right, it's just a demonstration.
When supply voltage is 91V output power:
1) 500W/8Ω. Zener diode must be selected so as to limit current to 12A (2.5 A * 5 or 3A * 4).
2) 1kW/4Ω. Zener diode must be selected as a transistor must be 8 or 10 pairs of 25A (2.5 A * 10 or 3A * 8).
Old 6th November 2009, 06:29 PM   #153
Federmann, in opposite to you, I had build in last twenty years several hundred mosfet amps and I had in my hands several thousand mosfets...I have practical experiences, not only these f... simulations like you...Show to us practical results, not only these theoretical blables
Old 6th November 2009, 06:37 PM   #154
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by Federmann View Post
Zener diode must be selected so as ...
I wonder if it is possible to make it so and to keep both linearity and protection. I am saying IT IS NOT.
Federmann, you argue here with people like Pavel Dudek (Upupa Epops) who has designed a lot of professional amplifiers that were sold in thousands, and with Ladislav Bunta (BV) who makes a living like an amplifier designer and producer, and again is commercially succesfull.
Contrary to that, you display some strange ideas, that are potentially hazardeous and dangerous for potential less experienced builders. You have no prototype, no sample. I must mention that, though I get a risk to be treated somehow. I hope there are some competent people who MUST see that.
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 6th November 2009, 06:46 PM   #155
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
Contrary to that, you display some strange ideas, that are potentially hazardeous and dangerous for potential less experienced builders. You have no prototype, no sample. I must mentione that, though I get a risk to be treated somehow. I hope there are some competent people who MUST see that.
It seems that the big danger is the technically not-competent person who does not see whatever danger may exist.
Old 6th November 2009, 06:48 PM   #156
PMA's Avatar
Exactly, you got it right.
Old 6th November 2009, 07:01 PM   #157
I agree; it is NOT possible.
Old 6th November 2009, 07:48 PM   #158
BV is offline BV  Slovakia
Overcurrent "protection" is one mistake, showed frequency compensation second.. It will be for sure power oscilator (for short time before explosion), slow output stage and "fast" input and VAS without local compensation closed in global NFB..Unrealistic. We have to wait for measured results.
Old 6th November 2009, 07:53 PM   #159
PMA's Avatar
To explain a bit. 5 years ago I posted a thread
New error correction amp
This thread described MOSFET output stage with error correction. The output devices were Hitachi 2SK413/2SJ118, similar to IRF range of devices rather than to laterals. The circuit operated pretty good, with one exception - the error correction acted as current limitation as well. It did not enable dVgs of both output MOSFETs above some level. It was fine, until the dVgs limit was reached - then horrible current limitation appeared, with terrible sound effect.
There is a similarity in the design discussed here. dVgs must be let to find appropriate level according to drive and output voltage. It cannot be used as a current 'protection'. It is impossible to achieve this goal without loosing linearity and rated power.
The current protection must be done in a different way. Also, it was proven in this thread, that hexfet MOSFETs cannot be paralleled without source resistors. These are 2 basic technical issues of Federman's design.
Old 6th November 2009, 07:53 PM   #160
PMA's Avatar
You are right, Jacco.
Closed Thread
UcD like topology amp. Bender.ru Class D 222 Yesterday 03:49 PM
Anyone seen this amp topology before? BlackUnikorn Tubes / Valves 14 6th August 2008 09:51 PM
Page generated in 0.12341 seconds (79.23% PHP - 20.77% MySQL) with 11 queries
