#131 | |
![]() ![]() Your involvement is not even my involvement, I wonder why submit the involvement of entirely different? ![]() Please look at what's over those colored circles in the text written on each diode in my text. |
#132 |
It is the same output stage, same 'protection' by 10V zeners. Wire from midpoint of zeners already added, regardless that there is no current limitation in any safe area.
#133 |
For even harder load, 0.1 ohm, the output collapses in simulation. In a real world transistors smoke.
#134 | |
Quote: „Chceme-li dosáhnout u tranzistoru IRFP9240PbF saturačního napětí v rozmezí 2÷3V a zároveň proudové omezení v rozmezí 4÷4,5A, použijeme omezení napětí UGS v rozmezí 5,1÷5,4V. V tomto pracovním bodě je vhodné spojované tranzistory překontrolovat. Obdobné hodnoty vyjdou pro saturaci v jiném pracovním bodě.“ "If we want to bring the transistor IRFP9240PbF saturation voltage in the range of 2 ÷ 3V while current restrictions in the range of 4 ÷ 4,5 A, will use UGS limited voltage range 5.1 ÷ 5.4 V. At this point it is appropriate to the work associated transistors check. Similar values come to work in a saturation point. " |
#135 |
Here is why it will not work well without source resistors. Let's look at Vgs = 4.5V and Vds > 10V. In that case, the drain current is:
For temperature = 25 Celsius, it is Ids = 0.6A. For temperature = 150 Celsius, it is Ids = 25A. That is not a reduction in current with increased temperature! All the parallelled transistors have the same Vgs so the hottest one will work harder than the others. Drawing a load line and pointing at it is nonsense. It is current sharing that is the problem, nothing to do with the load line. However, the BUZ9** transistors you mention on your page do not have this problem. They can be parallelled just fine without resistors.
The bewitching snivvie is dulcet paragon. |
#136 | |
Nice evening. |
#137 |
so what about real world examples?
One German 'high end' kit manufacturer has switched towards source resistors: Old 1994: http://www.thel-audioworld.de/module/acuso/AcS94a.jpg New 2003: http://www.thel-audioworld.de/module/acuso/AcS101a.jpg I'm now waiting of your pictures. Does a prototype exists yet? Regards |
#138 |
Hi Federmann,
The unanswered question is still there. Do you have a working prototype, or is it still in the conceptual stage right now? Simulators tend to give very optimistic performance numbers. We have seen many simulated designs that do not work in real life. Therefore, I think our members are interested in real measurements. -Chris
"Just because you can, doesn't mean you should" © my Wife |
#139 | ||
#140 |
Please put the load resistor value as 0.01 ohm. This would simulate short-circuit condition.
| UcD like topology amp. | Bender.ru | Class D | 232 | 21st March 2012 03:55 AM |
| Anyone seen this amp topology before? | BlackUnikorn | Tubes / Valves | 14 | 6th August 2008 08:51 PM |
| Page generated in 0.13518 seconds (77.66% PHP - 22.34% MySQL) with 11 queries |
