I have a leach amp working well, very low output offfset ( below 3 mV ) but at turn-on a massive DC bump that push speaker full travel.
Where should I look first ? capacitor in feedback loop ? power supply simetry at turn on ? |
#2 |
Most amps will do this due to the high loop gain and the big initial input error on power up. Most of us use a delay relay which connects the outputs after the amp has stabilized. Usually part of a protection circuit..
You could do same with changeover switch, or just plug speakers in after turning amp on. |
#3 |
According to professor Leach, you could get a bump if the main filter caps are not fully discharged when you turn the amp back on. Do you have bleeder resistors across the main filter caps?
Edit: My Leach amps use cheap PSU caps and I don't get a bump even without bleeder resistors or a delay. |
#4 | |
| My Leach Amp Clone (LEACH 150) | panson_hk | Solid State | 28 | 15th August 2011 08:12 PM |
| High Current Leach/leach super amp | bowdown | Solid State | 41 | 2nd March 2011 02:15 PM |
| Leach Superamp vs Leach 4.5 | Samuel Jayaraj | Solid State | 4 | 26th October 2002 09:20 AM |
| Leach amp vs super Leach amp | supernet | Solid State | 0 | 21st February 2002 10:16 PM |
| Leach Amp: help troubleshooting | swede | Solid State | 19 | 18th January 2002 04:06 PM |
| Page generated in 0.08939 seconds (68.85% PHP - 31.15% MySQL) with 10 queries |
