Old 25th October 2009, 12:54 PM   #1
Default Question about Class-A Amplifier.
hi there
actually i have a class-A amp which is very popular in internet and it's some how i like it and with just some modifications it's gonna be hi-fi in addition to it's extraordinary low cost.
but the PROBLEM is the power dissipation is maximum when there is no signal so i wanted instead of using a complementry output or AB push pull and a way from crossover distortion i was thinking what if used a transistor as a switch for the supply controlled by the input signal where if the input is quite enough it's applied to a rectifier then it's used to either ON the transistor and connect the supply or OFF and no supply .
finally when there is a signal there is power and no signal no power.
so what do u think guys
2N3055 Power Amplifier
thanks for reading.
Old 25th October 2009, 01:38 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
you already have power switch on it
better use your energy to find everything about origin , and how to make it better
The Class-A Amplifier Site
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 25th October 2009, 02:24 PM   #3
i'll give it a try.
but seems good to me.thanks
Old 25th October 2009, 02:57 PM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
Have you ever thought of using a tracking power supply? Something like cascoding the output stage with a class D amp.
All the trouble I've ever been in started out as fun......
Old 25th October 2009, 06:07 PM   #5
well...i don't know about it but gonna be happy if you show me how or lead me to know how ??
Old 25th October 2009, 06:43 PM   #6
tiefbassuebertr's Avatar
Originally Posted by Brownstocker View Post
hi there
thanks for reading.
I would not prefer an intelligent and comfortable solution, because the cost is too high and also you have not easy design.
I would introduce a high quality switch for two values of idle current; one of 20-30 mA (class AB for Pop/Rock and background music), and one of pure Class A (the currently value) for nearest perfect sonic quality.
An another solution it could be, to introduce a separate power supply for the output stage; but variable through switching the transformer windings (e.g. 4 voltage levels). At low volume, the power loss can then be kept smaller and if you want louder to hear another voltage value you must select, which is higher.
For this one to perform automatic (depend of the peaks in your music program) I haven't a solution, because I must then develope Class G or Class H. I don't like such solutions, because you have still the possibility of bi-amping - pure class-A for the upper frequency range and Class AB (good used amp e. g.) for the lower aera. This is the royal way in most cases
Old 25th October 2009, 07:20 PM   #7
Nice solution too..
i think i may use the separate power supply solution because it's the simplest.
or to use the bi-amping that's good too.but here in bi-amping the problem is i never design an amplifier before so i may guess how it gonna be but not sure of that..??
My first class A amplifier meanman1964 Pass Labs 42 15th February 2008 07:32 AM
class-A PP amplifier with 2x 845 question hesener Tubes / Valves 4 22nd December 2007 09:46 AM
Class D Vs Class I (Balanced Current Amplifier) rmsaudio Class D 28 29th September 2006 07:03 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.11334 seconds (77.10% PHP - 22.90% MySQL) with 10 queries
