Old 25th October 2009, 10:49 AM   #1
Default Single rail precision full wave rectifier - full gnd->rail DC swing possible?
I need to rectify an audio signal (max 4.8Vp-p)...and I'd like to get the maximum DC representation of this signal.
Ok, so if you type in precision full wave rectifier into Google, it sems best in class (or perhaps I should say most popular), is the Rod Elliot one here...
Simple Precision Rectifier (figure 6)
but the thing is, Rod uses dual rail opamps -my situation is limited to single rail - 5V. So I create a virtual ground at +2.5V & then use the same circuit but just running all those ground connections in Rod's circuit to my virtual ground. For a 4.8Vp-p input I get about 2.4V full wave AC output - all is good so far.
But as I say, extracting the DC component out of that signal will only give about 2V, So I need to amplify this full wave AC signal *but* also clamp/base the lower part of the waveform to ground - therefore what I want to achieve is a 0 thru 5V(ish) swing. So I messed about with Multisim & came up with this....
As you can see the output is about 3.6V DC - this is the best variant I can come up with (I'm not the best designer in the world - designing circuits being fairly new to me).
So ...has anyone got a better circuit or if not could some be so kind as to outline how to extract the maximum DC from an incoming signal of 4.8V peak to peak? (for a single 5V supply)
Many thanks
Old 25th October 2009, 01:15 PM   #2
Not sure what went wrong with that image file, let's try again...
Suggested AWG for 6.3V tube heaters rail and 250V B+ rail eranrund Parts 0 3rd November 2008 07:30 PM
Using split rail supply for single rail DC DanX Chip Amps 1 15th March 2008 05:18 PM
Filter Cap Directly from Rail to Rail, excluding Center Tap Workhorse Power Supplies 8 29th August 2007 12:33 PM
Single Rail full bridge self oscillating amplifier Anthony C Smith Class D 7 31st December 2005 10:08 AM
Page generated in 0.08356 seconds (69.61% PHP - 30.39% MySQL) with 10 queries
