Hi, I take the idea from:
the Headphone amplifier and I change the circuit a little, Vbe Multiplier, and put power output transistor (TIP3055/2955 ). I built the amplifier in protoboard, and sound incredible good! better than SiliconChip 20W. I accept ideas and sugestions to modify or upgrade the circuit. The original circuit (Pioneer) use all cascode stage, what do you think about this? Juanma PS: my english is bad
- Music by John Williams - |
#2 |
It has got a sort of diamond input.
Haven't seen this solution before.
lineup |
#3 |
Yeah, and some kind of CFP part of it too? And onother CFP in the output, for the drivers, provides plenty of drive for the output devices - at least on my TGM3 I found it a noticeable improvement over regular two stage EF.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#4 |
CFP or Sziklai is also one favourite of mine.
It has lower distortion than 2T darlington. I have run test with SPICE. I am now trying to do some No global feedback designs of power amplifier So far I am experimenting.
lineup |
#5 |
Lineup, did you ever see this one before:
http://www.angelfire.com/electronic/...less-Tube.html my plan for no feedback includes at least one vacuum tube for voltage amplifier. I'm still exploring ideas, but they're a bit scattered e.g. CELLINI-2 a hybrid Integrating tube into F4 ? Modified Wavebourn Tower II ? would love to see your ideas.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. Last edited by Bigun; 16th April 2011 at 11:36 PM. |
#6 |
Tube idea is good. They are good voltage amplifier.
That angelfire circuit uses feedback. Both local and global. I have not come far. When I find some good way I will show it. I only have tried with resistors to set local gain in stages.
lineup Last edited by lineup; 17th April 2011 at 06:33 AM. |
#7 |
You're right, that's strange though as I remember a version of that Angelfire amp without gnf
#8 | |
Make the output stages work in near classA and readjust R26 and R27, may be up to kilo ohm |
#9 |
It is not easy to create a global feedback free power amplifier with low THD.
It often involve using heavy use of local feedback and degeneration emitter resistors. Sziklai, or CFP complementary feedback pair, means 100% local feedback. So use of Sziklai is one way.l Use of high supply voltage, Class A output and lots of resistance is another.
lineup |
#10 |
Or don't worry about THD, only how it sounds.
| Global Feedback on Mikael's KT88SE | porkchop61 | Tubes / Valves | 7 | 28th May 2008 11:29 AM |
| Zen amplifiers and global feedback | teodorom | Pass Labs | 19 | 20th October 2006 07:47 PM |
| Non (global) feedback amp/hawksford | PanzerLord | Solid State | 6 | 11th December 2005 11:23 AM |
| JLH without global feedback? | rmgvs | Solid State | 6 | 10th June 2004 05:10 AM |
| Buffered IGC and global feedback? | JoeBob | Chip Amps | 1 | 3rd October 2003 11:23 AM |
| Page generated in 0.10740 seconds (85.05% PHP - 14.95% MySQL) with 11 queries |
