Hi I am new to this forum. I got the following transistor matching circuit from the internet it is quite simple and easy to build but the upper section (for NPN measurement) of the circuit has one 10K resistor connected between the two transistors while the lower section (for PNP measurement) has none. Would anyone please tell me is this a drawing mistake? Which one is correct? Thanks.
#2 |
Your picture is too small to see.
#3 |
#4 |
frugal-phile(tm)
That is still the same size as the last posted image.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5 |
Planet10
I now have the same problem when posting images here, that are hosted by ImageShack. Even though the original picture may be quite large, since the DIYAudio upgrade, it is the thumbmail that is being used , instead of being able to use the clickable option for a large image. Perhaps as a Moderator, you may be able to find out why the original option no longer works. It certainly still functions in other forums. Regards SandyK |
#6 |
The original image is a Jpeg 100k file. It has been compressed when uploading to the thread. Could anyone help to post it with a bigger size if I send him the file?
#7 |
Make a PDF file and attach that or email it to me.....
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#8 |
Hi Jan
Thank you for your help. I am pleased to attach a pdf file of the circuit. Thanks Albert |
#9 |
Electrons are yellow and more is better!
First of all, why do you want to match transistors? The question is for leading you to something else. Maybe you don't need to match at all?
/Per-Anders (my first name) or P-A as my friends call me |
#10 |
| Transistor matching | graham-r | Parts | 1 | 6th May 2009 07:21 PM |
| ltp transistor matching | sakis | Solid State | 16 | 7th January 2009 05:33 PM |
| transistor matching | derekyu | Solid State | 38 | 26th May 2007 07:57 AM |
| How to matching PNP with NPN Transistor | senee | Solid State | 16 | 7th March 2005 11:12 PM |
| transistor matching - stupid newbee question | hexman | Solid State | 6 | 26th February 2005 01:05 PM |
| Page generated in 0.11713 seconds (78.57% PHP - 21.43% MySQL) with 11 queries |
