Old 26th July 2010, 02:42 AM   #101
lanchile's Avatar
Originally Posted by DCPreamp View Post
I'm really impressed with the Goldpoint attenuator and input selector I used in my last preamp. A little pricey, but very well made and add nothing to the sound.
Paul
Very nice unit for sure.
Old 18th December 2010, 07:01 PM   #102
wuwhere is offline wuwhere  United States
I will be purchasing a TKD vol pot, 100kohms, is the 2CP-2508 better than the 2CP-2511? Thanks.
Old 1st January 2011, 09:30 PM   #103
HP8903B is offline HP8903B  United States
What do you guys think of this stepped attenuator on ebay:
33 Step 100K Volume Control DACT ELMA TKD 2A3 300B tube - eBay (item 150539240706 end time Jan-01-11 20:17:34 PST)
Has anyone tried this unit?
It look a lot like the Seiden unit.
Old 1st January 2011, 11:29 PM   #104
sendler is offline sendler  United States
Default Shunt?
They say it is a 100k ladder type but it only has two decks and requires a fixed 20k series resistor? I think it is a 20k switched shunt type which is only suitable to precede an active stage of 100k input impedance or higher with minimal cable in between. 1.2db per step is too close and only gives a total of 40db of range. I have 2db per step attenuators and if I am going to get up to change the volume, I usually end up changing in 4db increments unless I am doing level matched comparisons between components.
Scott
Old 1st January 2011, 11:49 PM   #105
From what I understand, a 33 step ladder type would have 66 resistors PER channel right?
Old 2nd January 2011, 12:16 AM   #106
I think you are right that it is shunt type.
However, the resistors appear to be soldered in series.
Old 2nd January 2011, 12:24 AM   #107
Default Series
It could be a series type but then I don't understand why they would send two pairs of 20k resistors.
Scott
Old 2nd January 2011, 04:54 AM   #108
Default Rotary Switch to Trigger I/O function as well as input select?
Hello, I was wondering if a rotary select for input switching could also function as an I/O for say a phono preamp. Like, 3 inputs cd/aux/phono but the phono also connects the mains to the phono preamp? Can this be done with a three deck rotary?
Old 20th March 2011, 07:03 PM   #109
tiefbassuebertr's Avatar
nwe rotary sw. from Shallco - discuss
New Shallco Switches
Old 8th June 2011, 12:36 PM   #110
Originally Posted by glen65 View Post
Thanks for the reply,
Its definitely a balance control because that's where I pulled it from.
You're correct it is an Alps control. I'm looking for something to replace
it because it's open. Ive seen some other controls that could work physically
but the resistance is only 10K. Its being used in a receiver where the preamp
consists of a 4558 op amp. If I cant find something with a high enough
resistance I guess my only other alternative would be to find out if the
circuit could be reconfigured to use something with a different resistance
value.
Please let me know the model and brand of the amplifier, where this ALPS balance potentiometer is in use. I am interesting on the circuit topology, bacause I have never seen before for balance adjust such a pot with four instead commonly three pins.
Penny & Giles : Good or not for HI-FI ?? arold19 Parts 21 2nd January 2013 01:47 PM
FS/Trade: Penny + Giles Cobra2 Swap Meet 5 13th December 2009 05:52 PM
ALPS Potentiometer Kriskom Parts 7 13th December 2009 05:51 PM
WTB: ALPS RK27 250K Potentiometer mrdon Swap Meet 14 6th August 2008 11:17 AM
Help with vishay/alps/bourns models tobias_svensk Parts 0 6th February 2004 06:20 PM
Copyright ©1999-2013 diyAudio
