Old 22nd October 2009, 09:23 PM   #1
Default Qsc amps with "flying power" supply?
Hi!
It would be interesting to know ,has anybody tried to build as diy these kind of power amps like QSC is designing? Check their website and find from archive the scematics.Interesting solutions ca 30 years and still working!
The next i try is make the qsc amp design and study it.I`m very interested about other members feedback and experiences...
Thanks.
Hannes
Old 22nd October 2009, 11:05 PM   #2
llwhtt is offline llwhtt  United States
I have QSC 1400 (with a flying power supply) sitting here that needs a rebuild. Haven't decided if it is worth it or not. Peavey is/was another big user of the topology. Haven't searched for an opinion of audio quality yet.
Craig
Old 23rd October 2009, 09:47 AM   #3
Default Have`nt any scematics for Peavey pa .. to compare
with so called flying power supply.There`s no anything special in the topology,but for diy its quite simple -power transformer is without zero midpoint and what`s more important-end stage transistors can be mounted without insulation washers directly to heatsink.....+the speaker is galvanically not connected to power supply at its ground-end(when s.. happens with end-stage transistor-there`s no danger of dc accsess to driver ..or what?)
Last edited by Hannes1962; 23rd October 2009 at 09:53 AM. Reason: Broken english.....
Old 23rd October 2009, 10:09 AM   #4
Frank Berry's Avatar
I've see Jukebox amplifiers with "flying" power supplies. The only limitation with that topology is that the channel 1 and channel 2 amplifiers can't share the same power supply. Otherwise, they seem to work well.
Frank
High Voltage Power Supply PCB "oopsie" Sale Geek Swap Meet 1 2nd January 2009 05:06 AM
"rule of thumb" used to determine xxVA for a power supply's transformer? CopyofAudiófilo Chip Amps 11 22nd July 2008 12:01 PM
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 1 27th May 2006 03:41 PM
"BPA 400"? Other high power chip amps? AAXenoStrange Chip Amps 5 17th February 2005 04:57 PM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
Page generated in 0.08703 seconds (70.69% PHP - 29.31% MySQL) with 10 queries
