Potentiometer like Alps for complete disassembly wanted
Old 22nd October 2009, 07:19 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default Potentiometer like Alps for complete disassembly wanted
there are two screws at backsite on the blue alps potentiometer, but I can only remove the backsite. Unfortunately I cannot disassembly the whole device
because there are no removable elements on the shaft
I need a version special made for complete dismanteling to cleaning and polishing the contact aera and the brushes. Who knows more about such potentiometers?
I recall, that a very old and very large version from Alps allowed this.
Old 18th February 2010, 04:34 PM   #2
I still want such attenuator versions for disass'y (screws instead the commonly riveting)
Old 15th September 2011, 01:18 PM   #3
are there any news?
I need potentiometers for disass'y in the same mounting kind than follow rotary switches:
http://www.lorlin.co.uk/PDF/PT.pdf
I know only "one-way mounting" versions like the following pics (start at image number 2).
By the blue version there are two screws, but no removable elements on the shaft, unfortunately covered by the white type sticker.
Old 16th September 2011, 04:38 AM   #4
gmphadte is offline gmphadte  India
Check whether the insides r heat pressed, else pushing the shaft will get the guts out.
Gajanan Phadte
Old 16th September 2011, 05:32 AM   #5
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Here you go.......
ALPS Potentiometer RK50112 10K 50K 100K 250K RK50 pot | eBay
Old 16th September 2011, 06:30 AM   #6
Originally Posted by theAnonymous1 View Post
o.k. an attenuator for nearly US-$ 1000,-- resp. 700,--
Old 16th September 2011, 06:38 AM   #7
Art M is offline Art M  United States
Default How about Noble
Will this work ?
Old 16th September 2011, 07:13 AM   #8
Yes, I was joking of course. A ridiculous price for any form of volume control, let alone a simple pot.
It can be disassembled though.
Old 16th September 2011, 09:44 AM   #9
Originally Posted by Art M View Post
Will this work ?
Attachment 240228
Thanks for the picture.When also the shaft fixing is for disass'y, this would be an appropriate choice (please send also a picture from the shaft fixing so as the brand name).
Basiclly I need a pot like the blue Alps, but with metric threads, two nuts (one of them self-locking), and spring-rings on the shaft (in the aera behind the sticker) for adjust the pressure of the lamellares for contact.
I wonder, why not a lot of companies offer such attenuator/potentiometer kits (as usual by rotary switches).
No joking. I have used this pot two times for amplifier upgrade for devices, that are very often in use by a DJ.
A precision device - indeed. And very good suited for disass'y and cleaning. The costs of this small amp model at whole (Cambridge Audio A1) are approximately half of that one of the potentiometer.
Old 18th September 2011, 05:10 AM   #10
Default NOBLE potentiometer guts
Here are a few more photos. The whole potentiometer is easy to break down.
Potentiometer like Alps for complete disassembly wantedHide this!Advertise here!
ALPS 100KAX6 MOTO potentiometer uhcmos Swap Meet 10 18th July 2012 10:12 PM
How to improve blue alps potentiometer Tolu Parts 3 25th January 2010 02:53 AM
ALPS Potentiometer Kriskom Parts 7 13th December 2009 05:51 PM
WTB: ALPS RK27 250K Potentiometer mrdon Swap Meet 14 6th August 2008 11:17 AM
Wanted: ALPS 20KAX4 potentiometer or equivalent tvicol Parts 5 9th October 2007 06:13 AM
