Old 22nd October 2009, 01:08 PM   #1
mckvak is offline mckvak  Czech Republic
Default Baxandall tone control circuit
Hi all. I look for a Baxandall tone control circuit, which can control bass and treable on 20dB or more. My english is not good I know sorry
Old 22nd October 2009, 04:13 PM   #2
Hi
Your English is good enough:
I hope this helps.
Max bass boost = (R1+R2) / R1
Max bass cut = R1 / (R1+R2)
Max treble boost = (R5+R1+2*R3) / R5
Max treble cut = R5 / (R5+R1+2*R3)
R4 shall be larger or equal to 10*(R5+R1+2*R3)
R2 shall be much larger than R1
In the example circuit:
Max bass boost = 20*log ((11k+100k)/11k) = 20dB
Max bass cut = 20*log (11k / (11k+100k)) = - 20dB
Max treble boost = 20*log ((3.6k+11k+2*11k) / 3.6k) = 20dB
Max treble cut = 20*log (3.6k / (3.6k+11k+2*11k)) = -20dB
Old 22nd October 2009, 04:58 PM   #3
It look easier than it seem. Is possible use transistor on the way out, because operations amplifier and another integrate circuit is not allow for my poject.
Old 22nd October 2009, 05:56 PM   #4
tiefbassuebertr's Avatar
additional informations and weblinks you can find here:
need equation for 3 band baxandall equalizer
Old 22nd October 2009, 06:29 PM   #5
Hi mckvak
Yes it is possible to use transistors instead of an opamp.
Maybe you should post the circuit you have made so far, that you would like to use the tone control with. If you have a gain stage maybe you should try to implement the tone control around that stage, or you could use a passive tone control.
stinius
Old 23rd October 2009, 02:05 PM   #6
This is the circuit. But way out sign as REC out I will not use
which tone control circuit? ruleworld Chip Amps 20 21st July 2009 04:24 AM
Baxandall active tone control jenks Solid State 3 18th April 2008 09:18 PM
How can I integrate a Baxandall Tone Control roger-k Solid State 9 16th July 2007 10:33 AM
baxandall tone control 9am53 Tubes / Valves 16 16th March 2005 06:44 PM
Baxandall Tone Control zee Parts 3 22nd December 2004 01:11 AM
Page generated in 0.08295 seconds (74.86% PHP - 25.14% MySQL) with 11 queries
