Old 21st October 2009, 04:55 AM   #1
Default Power cord replacement - ground?
I'm replacing the old power cord in my Yamaha M80 amplifier. The original cord has no ground, but my replacement does. What should I do with the ground lead?
I could wire-nut it... orrr would it be put to better use if it were attached to the chassis, for example?
Old 22nd October 2009, 03:10 PM   #2
Any help with this?
I'm also not sure which leads to connect to what... one side goes to my 2 power transformers on grey cord, and the other goes to a circuit board on a blue wire. The original wire doesn't help because it was there were no distinctions between either side of the plug...
Old 22nd October 2009, 06:00 PM   #3
jaycee is online now jaycee  United Kingdom
Live (line, active, hot, whatever you call it) should be in line with the fuses inside the unit.
You may connect Earth (Ground) to the chassis but it may buzz. If it does you can either disconnect the earth and leave it disconnected, or (the correct thing to do) make a loop breaking circuit so that it wont buzz.
Old 22nd October 2009, 06:09 PM   #4
Juergen Knoop's Avatar
just replace the powercord with the same 'type' as the original one was.
Earthing things that never meant to be connected to protective earth is a desaster recipe in audio.
stopping a ground loop through the power cord Bama Slamma Solid State 9 11th May 2007 12:08 AM
Page generated in 0.07886 seconds (69.07% PHP - 30.93% MySQL) with 10 queries
