There are some great videos on YouTube about Analog IC design from the Indian Institute of Technology that have a lot of material that is very applicable to audio design as well. In one of the videos on differential amplifier characteristics the professor mentions that early generations of op amps had a problem with latchup, where when the common mode voltage to a differential amplifier with a current source tail and resistive load became excessive the negative feedback around the amplifier would turn positive and cause the output to slam to one of the rails and stay there. He also states that using current source loads helps ameliorate this problem.
I'm having some trouble first understanding why the change from negative feedback to positive feedback occurs - is it because when the input voltage to the differential pair rises above the collector voltage the transistor has its base to collector diode forward biased and is behaving kind of like an emitter follower? Also, how does using a current source load help solve this problem? Any help in clarifying this issue in my mind would be greatly appreciated.
| Differential amplifier gain question | Bitrex | Solid State | 2 | 14th September 2009 02:10 AM |
| Differential to differential amplifier | Cauhtemoc | Solid State | 3 | 15th August 2007 07:39 AM |
| Differential amplifier mystery? | klitgt | Digital Source | 0 | 7th March 2006 02:07 PM |
| differential amplifier | Thomas Giz | Digital Source | 1 | 23rd March 2003 08:07 PM |
| Page generated in 0.07476 seconds (70.40% PHP - 29.60% MySQL) with 10 queries |
