Good evening, what are the benefits of amp mosfet
#2 |
Thermal stability compared to BJT?
#3 |
any advantages over BJT
#4 |
They dont need as much current to drive them.
i.e. you can drive a few MOSFETs straight from a VAS without buffering.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#5 |
I think people really value their speed when compared to BJTs. Without looking at the data sheets I think they can be an order of magnitude faster and this has something to do with the lack of "hole storage" effects I believe, but you'd need a more educated person to confirm that. Now that is probably "hard science" and could lead to the subjective effect that people think they are cleaner, have less "memory" allowing better musical production. (Don't want to get into an argument about the last point. Just passing on others comments, okay?)
"It was the Spring time of the year when aunt calls to aunt like mastodons across the frozen waste." P.G. Wodehouse. Last edited by Jonathan Bright; 19th October 2009 at 09:16 PM. |
#6 |
#7 |
They require about 20dB more feedback to get distortion down to BJT levels (unless running class A as Pass does).
Candidates for the Darwin Award should not read this author. |
#8 |
Did it Himself
You can find MOSFETs with very nice big safe operating area (SOA) curves, also they do not suffer from second breakdown and at very high currents have a negative temperature coefficient which again helps against destruction.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Mosfet Amplifier | Telnet100 | Solid State | 3 | 20th May 2012 09:37 PM |
| SE mosfet amplifier | noyan | Solid State | 7 | 25th September 2009 12:39 AM |
| MOSFET amplifier | ash_dac | Solid State | 6 | 5th December 2006 08:55 AM |
| MOSFET/MOSFET amplifier | jarek | Pass Labs | 21 | 22nd June 2004 05:04 PM |
| Page generated in 0.09265 seconds (74.10% PHP - 25.90% MySQL) with 10 queries |
