Hi All
I'm seeking some opinions or advice from the learned out there. I'm seeking to modify my triamped speaker setup to incorporate a larger ribbon top with my Scan speak revelator mids and dynaudio subs. Crossover is via a behringer dcx2496 Currently the tweeter is a DIY prototype using a Decca type matching Transfomer. I would like to construct a larger tweeter to extend range down through midrange and as far down as it can go. The issue is that i would like to consider a "direct drive" amp for the ribbon which will be in the order of 30" in length ( I have enough Neo magnets to construct it) Options are : 1. Use existing DIY amps Hafler DH-200 or Aleph 5 , either, with a resistor in series with the ribbon to raise impedance to something other than a short. 2 Attempt direct drive with no resistor - but from reading it seems this may not be a wonderful idea... 3. See how well the small existing matching transformer goes in handling more power - typically in the midrange and upper bass. I've tried option 1 with a 1.5ohm resistor and it seems to work fine at first listening on the Hafler (which supposedly can lump 10A into a short) , 4 ohm resistor also worked ok. Option 2 I'm a bit hesitant about trying.- not wanting sparks etc. Any comments ? -Particularly low impedance loading of the amps. In terms of the crossover frequency to the ribbon - i can dial in what i want with the behringer - until the ribbon sounds lousy or it breaks. many thanks in advance George Oh and yes the prototype ribbon tweeter works fine , but makes the revelator sound lacking.....hence the intention to upgrade
george a |
| A DIY Ribbon Speaker of a different Kind | Mandrake5 | Planars & Exotics | 200 | 16th May 2012 05:15 AM |
| Ribbon Bookshelf Speaker | LineArray | Multi-Way | 2 | 6th June 2008 11:38 AM |
| The start of another large ribbon speaker | fperra | Planars & Exotics | 11 | 7th February 2008 07:09 PM |
| New Ribbon Speaker Technology - Approach the perfect speaker? | cocolino | Planars & Exotics | 49 | 16th January 2005 10:12 PM |
| Page generated in 0.06985 seconds (70.57% PHP - 29.43% MySQL) with 10 queries |
