Newbie here needing advice. I need to replace a 1SS176 diode in my Carver TFM-25 amp but I can't find one. Here's the datasheet 1SS176 Datasheet pdf - SWITCHING DIODES - Leshan Radio Company
Is anyone familiar with that diode and can recommend an equivalent replacement? |
#2 |
Oops, the 1SS176 data sheet shows the number 1N4148 at the top. I just did another search and found a 1N4148 diode so I'm assuming that is the same diode?
#3 |
1N914/A/B should be an equivalent... it'll have the Vr needed.
http://docs.google.com/gview?a=v&q=c...54e4j1XaHPBHEQ Cheers! Last edited by Geek; 19th October 2009 at 03:39 AM. |
#4 |
if you have a data sheet see the features and check it in mouser and other site you get similar ones ..
| Suppressor diode equivalent in SMPS | andjur78 | Parts | 3 | 21st October 2008 09:40 AM |
| diode bridge - 10000uF cap - diode tube - small cap - HV+ | engels | Tubes / Valves | 5 | 29th January 2008 10:16 PM |
| hybrid power supply: diode bridge into diode tube | engels | Tubes / Valves | 8 | 24th September 2007 09:18 AM |
| Pioneer SA-8500, diode equivalent | munja | Solid State | 17 | 24th October 2005 05:43 PM |
| bjt equivalent | distortion | Parts | 1 | 7th March 2004 12:16 PM |
| Page generated in 0.06692 seconds (71.24% PHP - 28.76% MySQL) with 10 queries |
