Evenin' oh, wise ones...
I'm in the process of tracking down the 'issues' with an Audio Research D-52B. Have a driver transistor that is shorted across the Base and Emitter and will need replacing. Wondering if I should replace the lot of transistors while I have the beast apart. That de-soldering was a slice of heaven. Don't want to do that again if I can help it! The output pairs are 2SB555 and 2SD425 and the drivers are apparently MJ15003/4 pairs (AR P/N 30002600/...2700). Would MJ21193/4 pairs be a better choice for both drivers and outputs? Better to stick with MJ15003/4 for the drivers and MJ21193/4 as replacements for the 2SB555/2SD425? Other good choices? The D-52 and D-100 seem to differ only in numbers of transistors so a good replacement for the one would be good knowledge for the other. Thanks guys! Brooks |
| Audio Research D-90 | rudy129 | Tubes / Valves | 4 | 11th June 2010 01:19 PM |
| Audio Research St-70-c3 | dcb50 | Tubes / Valves | 0 | 2nd October 2008 04:18 AM |
| Audio Research D 400 MK 1 | Alex helge | Solid State | 1 | 21st May 2005 04:50 AM |
| Audio Research LS2 | Lourens | Tubes / Valves | 2 | 4th April 2004 07:42 PM |
| Audio Research Ls 2 | ben goh | Tubes / Valves | 5 | 14th June 2002 07:51 PM |
| Page generated in 0.06091 seconds (67.16% PHP - 32.84% MySQL) with 10 queries |
