Old 16th October 2009, 06:16 PM   #1
tomat is offline tomat  Indonesia
Default Loudspeaker thump
loudspeaker thump when amplifier turn on,what causing them? and how solve that?
thanks for the help
Old 17th October 2009, 05:50 AM   #2
destroyer X's Avatar
Default The time needed to load load electrolitic condensers or capacitors
you have , mainly into the differential pair long tail causes that...also others, alike bootstrap and second differential transistor does that.
The higher the resistances value you use together a high capacitance, then your time to load will be big too... and this takes time to stabilize (charge) and you will see the amplifier going to stabilization into the ouput line with your speaker movement.
Reduce long tail capacitors, use something that loads at ligth speed alike active devices..i use zener in my amplifiers.
regards,
Carlos
Try to build an amplifier folks ... it is pure adrenaline!
Old 17th October 2009, 09:33 AM   #3
thank you very much for the help,i will try
Old 17th October 2009, 10:05 AM   #4
paulspencer's Avatar
It can come from a number of different components, but most hifi amps will have a relay which mutes the outputs for around 5 seconds on powering up so that any thumps which may come from the amp or anything upstream won't come through.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 17th October 2009, 03:52 PM   #5
Default There are other noises that sometimes confuses us
the spike produced when you switch power on can be sensed by the amplifier and produce noises..not exactly what is considered power on "thump" but produces noises, sometimes have high and low frequencies together...a thump mixed with a "paft!"
Having that, include, increase value to 10n, or substitute your power on switch key capacitor.
I often use the one available, the high voltage one, between 10n and 27n
regards,
Carlos
Old 25th October 2009, 04:29 PM   #6
regards,
Carlos
Hi Carlos,
some time we see an amp using opamp ic on input stage,how if this happen on there
thanks
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 83 16th May 2011 12:27 PM
What is that thump,thump,thump? 65blkbkgt Car Audio 7 17th June 2007 01:35 AM
On & Off Thump Kinger Chip Amps 2 31st December 2006 11:46 AM
aikido thump jayme Tubes / Valves 16 29th October 2006 10:17 PM
Zen amp turn-on thump. vdi_nenna Pass Labs 2 22nd October 2000 07:27 PM
Page generated in 0.10231 seconds (78.19% PHP - 21.81% MySQL) with 11 queries
