A friend asked me, he wants to build...but he wants active!... the one is already knowing i am doing passive input filters to amplifiers.... i do not know how to make it active...i have just an idea about...can you help posting schematics?
Yes..i have a lot of good operational amplifiers if needed... but i would be more happy with discrete, because less stages means lower distortion (normally) Bass - 1 hertz to 200 hertz (-3dB) to the bass power amplifier unit (sub) Mids - 200 hertz (-3dB) to 4 kilohertz treble - 4 kilohertz and up. thank you in advance by your cooperation...i can discover how to do it..but will take a lot of time..having your suggestion will be easier.... and faster! Input and output impedance around 47K Gain of one, input 1 volt rms ...or something more modern and up to date you suggest. Volume potentiometer included into the input of these three filter channels..or active pré amplifier if you want to call this way. Help! regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! Last edited by destroyer X; 16th October 2009 at 09:17 AM. |
#2 |
esp shows active filters.
regards Andrew T. |
#3 |
Did it Himself
I have a modular active filter project on my website
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#4 |
To learn how to make it will spend a lot of time..and this is an issue..i had not too much free time time those last monthes.
You know....i have not the time to learn that..i have a dead line... this must be fast...i am searching for the stuff ready and tested..not to learn or develop. Will take a good look at ESP pages..maybe the filters there are "ready to go" regards, Carlos
Try to build an amplifier folks ... it is pure adrenaline! |
#5 |
thank you,
regards, Carlos
#6 |
Linkwitz has complete active crossover designs as well as generic theory pages
Active Filters http://www.linkwitzlab.com/xo_eq.htm http://www.linkwitzlab.com/crossovers.htm |
#7 |
"Is this correct?... can you please observe if i made errors"
It looks like you have made a series of nopass filters in that schemo (dead shorts across the op-amps). There is more to designing a filter than just connecting resistors to capacitors. What characteristics are you looking for? The Chebychev characteristic gives the best skirt selectivity at the expense of amplitude response and phase linearity. The Bessel characteristic has the best phase linearity, the poorest skirt selectivity, and a fair amplitude response. The Butterworth -- a good compromise between skirt selectivity, amplitude response (the best) and a well behaved phase characteristic, except it goes a bit wonky near its cutoff frequency. Here's what an active LPF ought to look like. The HPF simply interchanges the resistors and capacitors. (Attached). I'd always make the odd ordered filters, since it just costs you one additional resistor and capacitor. An extra -3.0db of roll off/on for cheap. |
#8 |
frugal-phile(tm)
Here is another theory page:
Body And if you are building the amp from scratch for dedicated use one could sandwich PLLXOs between stages: Passive High-Level Crossover dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
regards,
Carlos
#10 | ||
| Bob Pease on Active Filters | Speedskater | Solid State | 0 | 6th October 2006 10:24 PM |
| where to place active filters? | AndrewT | Multi-Way | 1 | 22nd October 2004 12:14 AM |
| Amp for active X-over, what power needed? | Kees | Solid State | 1 | 3rd October 2003 07:42 PM |
| input impedance of active filters.q | theChris | Analogue Source | 1 | 25th June 2003 11:07 PM |
| Which op amps do you use for active filters?? | zx3chris | Parts | 4 | 25th April 2003 06:42 AM |
| Page generated in 0.12307 seconds (79.03% PHP - 20.97% MySQL) with 11 queries |
