Hello,
Where is the best, current source for these printed circuit boards? Thanks and regards, Rob |
#2 |
I too want one channel cause the third is alone yet.
#3 |
The ver 4.5 is the Leach board and not one of the group buy boards. Look on the Leach website and contact him per instructions. He can be slow to reply so do not get discouraged
#4 |
#5 |
Or print two copies to scale using an inkjet printer onto transparency film, and visit a friend with who'll make boards in exchange for pizza and beer?
http://users.ece.gatech.edu/mleach/l...cs/layouts.pdf The far from best solution is to print the artwork to scale onto paper, tape that onto board stock, and drill all the holes. Then put the traces and pads on using resist ink or transfers or paint. Etch. |
#6 | |
The last time I went though that process it took hours and the results were so-so. I'd rather spend a few bucks, get something that actually works, and use that time elsewhere. I'd prefer to avoid building the amp, then discovering that it doesn't work because of an issue with the board that I inflicted on myself. But the friend idea is intriguing....... Still, I may revisit that idea if I have to change the board size/layout for some reason. |
| My Leach Amp Clone (LEACH 150) | panson_hk | Solid State | 28 | 15th August 2011 08:12 PM |
| High Current Leach/leach super amp | bowdown | Solid State | 41 | 2nd March 2011 02:15 PM |
| P3A Vs Leach | jamesjung21 | Solid State | 29 | 4th June 2004 01:27 PM |
| Leach Superamp vs Leach 4.5 | Samuel Jayaraj | Solid State | 4 | 26th October 2002 09:20 AM |
| Leach amp vs super Leach amp | supernet | Solid State | 0 | 21st February 2002 10:16 PM |
| Page generated in 0.08434 seconds (73.96% PHP - 26.04% MySQL) with 10 queries |
