Howdy -
I have a problem with my left channel of my JLH 80 watter. It's the last single PCB Wiliams Hart version - not the Hart version with separate boards for power supply & amplifier. Does anyone have a copy of the kit instructions with circuit diagram & parts list for the Williams Hart incarnation of the JLH 80 watt amp (mono or stereo - it's the same board). I would be so grateful if someone could help me out - There's a bottle of your favourite tipple in it - I love these amps and while I ordered the kit, it took so long to arrive (parts out of stock) that they sent me a ready built set with no instructions. my e mail is iestyn.morris@quiksilver-europe.com Any help much appreciated. |
#2 |
If this is the VMOS design presented in ETI many years ago, I still have the mag buried somewhere in my belongings...
![]() If someone else doesn't chime in, I may be able to dig it out. Will take some time though....
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals! |
#3 |
It looks like this :
J picture by bloodyhell451 - Photobucket Hope you can see it - I'm new to photobucket. Any help greatly appreciated - Best regards, rr |
#4 |
Hi, just came across your post, I have reprints from ETI in my hand, but I'm not quite sure about the hart version. The one I have is with the cut out for the transformer. Not quite sure if I'm allowed to attach a file so I will send it to your email anyway.
Ignore what i just said, i just looked and there is no schematic, but wait just found one lying around in a cupboard |
#5 |
which version is it I did have 2 versions, 1 with the cutout for the transformer and the one with the power devices on the main board. but both do not look like yours. I wonder how many versions there are.
Regards - Anthony Last edited by anthony.taylor1967; 13th October 2009 at 03:21 PM. |
#6 |
As far as I know there are only two versions. The one with the cut-out on the power supply board and the one with all the gubbins on one board. We actually have 2 of the 35 watt versions, one stereo 80 watt version (single power supply) and two monoblock versions in our family. I'm the chump with the last Williams Hart one board version. By Bro has the twin board set of mono's and the other three amps are all back home with the folks. I also use the fully discreet phono pre amp & outboard power supply (as dos my Dad) and I have the full on pre-amp with outboard power supply as well. All were built by us axcept (guess what) my mono's.
When I get back to blighty I'm gonna scan everything a put it online for other disciples. In the mean time I'd be very grateful for the one-board schéma & parts list. (number of resistor + value etc.) There's a bottle in it ! |
#7 | |
The reason for the new PCB (third) apparently, was that the performance was more built in - things like earthing etc, psu and amp on same PCB, and using newer plastic lateral mosfets (not T-O3). With the older PCBs there was alot you could do wrong constructing it if you where a novice. It would be interesting to see some of the updates for the latest one. What values changed for DC offset, gain etc and PSU changes. |
#8 | |
#9 |
As a follow up - I had the Williams Hart mono fixed. It turns out that the output transistors had blown - taking out some zeners as well. The engineer had quite a time.
I can confirm that the circuit diagram and the parts list is the same for both versions - though the Hart version is closer to the original design - running a higher quiescent current than the Williams Hart. The heatsinking arrangements for the Hart are better - the L shaped plate in the Williams Hart version is not up to the same standard. This is going to be the subject of a futre project. I can also confirm that APJ Audio JLH 80W amplifier boards is not only offering the boards for the Hart kit but is virtually able to supply complete Kits. I have ordered a power supply kit to turn a JLH Stereo Hart kit into a pair of Monoblocks. I don't think he has the transformer at the present time so that will have to be sourced elsewhere. I'll get back to you when I know more. APJ Audio can also supply the construction manuals - Thank god for this man ! Anyone interested in a pair of Monoblocks which can outperform commercial amplifiers up to £5000 (according to a friend who owns some very highly regarded examples of the breed) should give this man some custom ! Best regards rr |
| John Linsley Hood FM tuner article/s | djsb | Analogue Source | 5 | 27th June 2009 04:18 PM |
| John Lindsey Hood amps | Professor smith | Pass Labs | 7 | 11th May 2009 06:42 PM |
| John Linsley Hood RIAA Preamp? | roger-k | Solid State | 5 | 16th March 2007 07:10 PM |
| Lindsley Hood Powertran 75 | Lasse- | Solid State | 0 | 16th January 2004 12:33 AM |
| John Linsley Hood "Valve and Xstor" amps | jackinnj | Swap Meet | 0 | 4th July 2002 02:14 AM |
| Page generated in 0.09765 seconds (88.09% PHP - 11.91% MySQL) with 10 queries |
