Old 12th October 2009, 10:14 AM   #1
Stee is offline Stee  Italy
Stee's Avatar
Default Quasi-Balanced Method
Hi
my new Hybrid amplifier works with a particular system
preamplifier is a SRPP of 6SN7
amplifier are double on each channel (Lite A-680 DIYGENE) in bridge
but "Cold" amplifier don't have signal in input - Not Connected
sounds GOOD
http://www.esafono.it/quasi_balanced.htm
visit my best audio idea http://www.esafono.it/DACTONE.htm
Old 12th October 2009, 10:34 AM   #2
GK is offline GK  Australia
Originally Posted by Stee View Post
...in bridge but "Cold" amplifier don't have signal in input - Not Connected
sounds GOOD]
Old 12th October 2009, 10:54 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
[snip]
sounds GOOD
So why is it there? Why not just ground that side of the load?
jd
/Another new issue: Linear Audio Volume 3!
Old 12th October 2009, 11:48 AM   #4
jd
Because he was afraid that it could look even more uninventive (I have to resist to write more appropriate words)!
If you are arguing with an idiot, first make sure that he is not doing the same thing.
Old 12th October 2009, 12:01 PM   #5
janneman's Avatar
Well he must have a reason, maybe it is a good one. I looked at his website but couln't figure it out, my Italian isn't that good.
jd
Old 13th October 2009, 08:37 PM   #6
Stee's Avatar
Default ghost Stage instead ground
The compensation of the "character" of bipolar devices in complementary symmetry amplifiers
Normally occurs with the overlap of the curves PNP and NPN entire waveform:
Class A inappropriately use the method of complementary
. Because it does not comply with the direction of the curve.
To obtain an accurate compensation is required
Synchronizing the operating point of the two curves P and N
In the direction of work (increase / decrease) consistent.
This consistency in the pattern of vectors is "Bridge" or Balanced (Class AB)
To obtain an excellent result with the Class AB balanced (or bridge)
It requires, however, a perfect symmetry of the signals between the hot and cold branch.
Quasi-Balanced configuration is not bound by this requirement
As the signal is single (unbalanced) then the amplifier "cold"
It acts passively by providing current as a function of the amplifier "hot"
(to maintain balance in the DC voltage)
Making a component Tonal balance seemingly useless
But can cancel like a mirror with great accuracy the emphasis of the components.
(Google translator)
Old 13th October 2009, 08:42 PM   #7
Stee's Avatar
Default an example
for better understanding
Old 13th October 2009, 09:20 PM   #8
cbdb is offline cbdb  Canada
This is wrong. The math is simple and probably easy to find in www. land.
Old 17th October 2009, 10:27 AM   #9
Stee's Avatar
Default please see also the application on tubes preamp
http://www.esafono.it/ISY.ZIP
Old 17th October 2009, 03:21 PM   #10
janneman's Avatar
I see what you mean. Interesting thinking, but I am not sure it works that way. Let us suppose that the driven amp has the 'N' curve. This curve is the result of several things, like non-linear amplification and non-zero output impedance.
The not-driven amp only has an error due to it's non-zero output impedance because it is not driven. Why would that error be the exact complement of the non-linear amplification of the N part?
jd
Quasi or not Quasi - that is the question x-pro Solid State 31 26th May 2010 11:34 AM
Balanced quasi-floating output xocoatl Parts 2 30th December 2004 01:18 PM
Page generated in 0.11182 seconds (78.24% PHP - 21.76% MySQL) with 11 queries
