Old 9th October 2009, 01:31 PM   #1
Default 500Watts plate ampl circuit
All,
i need a circuit of a plate ampl capable of delivering 500 watts rms for my sub
thanks in advance
Old 9th October 2009, 05:27 PM   #2
fotios is online now fotios  Greece
fotios's Avatar
How many drivers included in your subwoofer?
A single driver of 500Wrms?
Two drivers of 250Wrms each?
Also the Z (in Ω) of each driver?
Best Regards FOTIS ANAGNOSTOU
Direct Contact: eal@dra.forthnet.gr
Old 30th October 2009, 10:47 PM   #3
Default plate ampl
my driver is sony xplode and has these data:
peak power 1100watts
freq response 18hz to 2500hz
rated power 300 watts
impedance 4 ohms
what i need is a plate ampl that can deliver 500watts rms output into 4 ohms i can choose the driver to suite i intend using a single driver.
thanks
Old 31st October 2009, 11:58 AM   #4
tiefbassuebertr's Avatar
impedance 4 ohms
thanks
go to Hypex Electronics B.V.
(mostly Class-D)
If you prefer Class AB, there are the older models "A 750" and "A 1500" from the same brand
A750
3-stage DC-coupled Ampl korneluk Tubes / Valves 9 8th April 2009 07:19 PM
a filter for 500watts amp umut1001 Class D 12 7th April 2009 12:48 AM
500watts Amplifier help darkkiller Solid State 29 30th April 2008 11:36 PM
Can I use Philips TB2.5 /400 in a SE ampl. Hojvaelde Tubes / Valves 4 14th June 2005 12:39 PM
Page generated in 0.09350 seconds (74.44% PHP - 25.56% MySQL) with 10 queries
