Dx TriAmp bass unit
Dx TriAmp bass unit
Old 10th October 2009, 12:51 PM   #41
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default The back side, the transistor's back metal plate used not to be flat
this results the parts you see as copper colour are the parts are alike mountains and they would touch the heatsink..the lower parts, the valleys, the deep parts are the ones not touched by the waterproof, grain 500, sandpaper
The sandpaper was placed over a flat surface, a glass plate..and then i move the transistor to erode till turn it flat..you see material was removed into the parts you see copper...now it is flat.
If you do not do that, then the parts are higher, the projections, to the metal bubbles, the peaks, the hills, the mountains into the metal surface, will be the ones will touch the heatsink..this will reduce (a lot) the heat transference.
Check your transistors..you gonna be very surprised.
regards,
Carlos
File Type: jpg Actually the brass colour touches the heatsink.jpg (211.4 KB, 205 views)
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 10th October 2009, 03:20 PM   #42
Default Now, some circuit details
Dx Amplifier – bass unit – to work with 62 plus and 62 volts minus
Was made (adjusted, tuned, tweaked) to work from 1 hertz to 300 hertz (-3dB)
Sensitivity – 1 volts rms to full rated unclipped output. (39.75 Volts rms)
Input impedance – 39K
Output impedance – 8, 6, 4, 2 and 1 ohm.. depending the quantity of power
transistors used into the output
Power amplifier details with sinusoidal input signal, and delivering 39.75 volts to
the load:
197 watts rms at 8 ohms, 200 Hz input with 1 volts rms of level, rail current
2.26A, and supply voltage at 62 volts to each one of the rails.
263 watts rms at 6 ohms, 200 Hz input with 1 volt rms of level, rail current
2.98A, and supply voltage at 62 volts to each one of the rails.
395 watts rms at 4 ohms, 200 Hz input with 1 volts rms of level, rail current
4.48A, and supply voltage at 62 volts to each one of the rails.
790 watts rms at 2 ohms, 200 Hz input with 1 volts rms of level, rail current
8.90A, and supply voltage at 62 volts to each one of the rails.
1135 watts rms, 1 ohm, 200 Hz input with 1 volts rms of level, rail current
14.9A, and supply voltage at 62 volts to each one of the rails.
regards,
Carlos
Old 10th October 2009, 03:30 PM   #43
Default About fuses and electrolitic condensers to the supply
About rail fuses and supply fuses… do not use fast blow
Operating with 8 ohms speakers, then use 2.5A fuse to each rail
and 5 ampere fuse in series with the output (speaker)
Operating with 6 ohms speakers, then use 3.0A fuse to each rail
and 6 ampere fuse in series with the output (speaker)
Operating with 4 ohms speakers, then use 5.0A fuse to each rail
and 10 ampere fuse in series with the output (speaker)
Operating with 2 ohms speakers, then use 10 A fuse o each rail
and 20 ampere fuse in series with the output (speaker)
Operating with 1 ohm speaker, then use 15A fuse to each rail
and 30 ampere fuse in series with the output (speaker)
About filter electrolitic condensers to the power supply
Operating with 8 ohms speakers, then use 12.500uf each rail
Operating with 6 ohms speakers, then use 15.000uf each rail
Operating with 4 ohms speakers, then use 20.000uf each rail
Operating with 2 ohms speakers, then use 50.000uf each rail
Operating with 1 ohm speaker, then use 100.000uf each rail
regards,
Carlos
Old 10th October 2009, 03:43 PM   #44
Default Continuing describing the power amplifier
Continuing with the specifications and details
The off set (Dc milivolts present into the output terminals due to
unmatching of transistor devices) is adjustable tweaking the 4k7
trimpot, pré adjusted to 3900 ohms (R23)..of set will be around
1.2 milivolts
Current crossing each power transistor is measured monitoring
voltage Dc, milivolts range, directly picking the voltage into the
emitter resistances extreme leads (0.33 ohm)… the voltage
to be measure may be 656 microvolts..and this results into 1.98
miliampere of current crossing each one of the power transistors
colector to emitter junction into stand by mode, with the input
shorted, so, no signal entering the amplifier circuit…. maximum
tollerable current to each transistor is 5 miliamperes each one.
Positive rail stand by current..having base shorted to ground, so,
no signal driving the amplifier…iddle mode, will be 37mA..and
this is measured using supply series protective resistance, that
resistance value is 10 ohms (10 watts minimum) and the voltage
measured directly into the extreme terminals will be 370 milivolts…
and this happens, only, when the power transistor emitter currents
are fine..or … measuring less than 2 miliampere to each power
transistors..and when they are 5 units…having more transistors, then
the current into stand by mode will increase depending the number of
transistors used.
Negative rail stand by current, having base shorted to ground, so, no
signal driving the amplifier… iddle mode, will be 29.4 mA…and this
must obbey all conditions written above….. this means 294 milivolts
measured over 10 ohms protective resistance.
regards,
Carlos
Old 10th October 2009, 04:01 PM   #45
Default Some currents and more details
Long tail current is 1.42 mA, so, half of that to each transistor into the differential pair
Bootstrapp/VAS current is 9.68mA
Driver current is 4.86mA
External VBE multiplier has 1800 ohms resistance from base to colector and a series of resistances from base to emitter....the first resistance is a fixed resistance of 750 ohms (or other you choice) and the variable one (trimpot) is adjusted into 150 ohms (can be a 220 ohms trimpot)...so..total resistance from base to emitter is 900 ohms... set this way during start up.
regards,
Carlos
Old 10th October 2009, 05:47 PM   #46
Default Post 44 had errors, reason why i am posting once again with corrections
unmatching of transistor devices) is adjustable tweaking the 10k
trimpot, pré adjusted to 7200 ohms (R23)..of set will be around
1.0 milivolts
to be measure may be 750 microvolts..and this results into 2.2
transistors used.
Differences in measurement around 20 percent plus and 20 percent
Minus are considered normal..do not worry with that.
Old 10th October 2009, 05:48 PM   #47
Default Post 45 had errors too... reason why i am posting it once again with some different
numbers..sorry folks..my mistake.
________________________________________
External VBE multiplier has 1800 ohms resistance from base to colector and a series of resistances from base to emitter....the first resistance is a fixed resistance of 1000 ohms (or other you choice) and the variable one (trimpot) is adjusted into 260 ohms (can be a 500 ohms trimpot)...so..total resistance from base to emitter is 1260 ohms... set this way during start up.
regards,
Carlos
Old 10th October 2009, 05:50 PM   #48
Default Schematic, revision number one.
attached,
regards,
Carlos
Old 10th October 2009, 05:52 PM   #49
Default Parts that does not exist into the Dx Amplifier standard pcboard
The one you can find at Greg Erskine home pages:
http://users.tpg.com.au/users/gerskine/dxamp/
image attached.
regards,
Carlos
File Type: jpg Parts not existent into the standard pcboard.jpg (720.0 KB, 165 views)
Old 10th October 2009, 05:54 PM   #50
Default Components that had their values changed
image attached,
regards,
Carlos
Dx TriAmp bass unitHide this!Advertise here!
Mission 720 bass unit repair Mark25 Multi-Way 27 24th January 2011 04:34 PM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 03:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 04:29 PM
Repairing bass unit in quad-63--HELP Williams Audio Planars & Exotics 2 14th October 2005 11:59 AM
Final 0.3 ELS bass unit and x/over systema Multi-Way 0 6th August 2005 07:56 AM
