Dx TriAmp bass unit
Dx TriAmp bass unit
Old 22nd November 2009, 05:20 PM   #151
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default Listen the TriAmp playing... recording made using electret condenser microphone from
Panasonic, model WM61.
There are noises, vibrations and some saturations.... not a very good recording, but show you the "idea" about Triple amplification.
All amplifiers are Dx amplifier, the standard one, wich schematic and needed instructions are into Greg Erskine pages.
here is the link...click the link please!
YouTube - Dx amplifier, triple amp playing, mic. audio rec.
regards,
Carlos
I am alive and healthy folks... for Brazil only product: https://www.youtube.com/watch?v=6A_g8uPHHO4: https://www.youtube.com/watch?v=DTXl1eEgygk
Old 24th November 2009, 12:40 PM   #152
Default Checking room acoustics and TriAmp performance
Dx Corporation works round the clock.
regards,
Carlos
Old 13th January 2010, 11:33 AM   #153
Default Active filter, made from Marcisium Laboratories, for the Dx TriAmp, is almost ready
Watch this.
regards,
Carlos
Old 14th January 2010, 06:31 AM   #154
Default Dx TriAmp, electronic input active filter is almost ready
Made by a Corporation satelite company, Marcisium Laboratories.
One more partner in the search of "Audio excellence"
Carlos
Old 9th February 2010, 08:26 PM   #155
Default I am working with the Dx TriAmp, preparing it to connect the active filter circuit
so, i am removing the passive filter and re tuning the boards, as they were adjusted to filter the spectrum not used...to filter frequencies outside the band choosen.
ImageShack -
regards,
Carlos
Old 28th February 2010, 10:05 AM   #156
Default Negative, the Dx TriAmp design is not dead.
Because nothing can beat that IDEA..... to separate audio bandwidth results better, not only to equalize, to adjust audio to your room acoustic, but also as this reduces distortions offering to each amplifier, a smaller audio bandwidth.
Of course, the Dx Blame ES sounds better than my old and delicious Dx Amplifier..so, i will substitute some amplifiers, from the Dx TriAmp, to use Dx Blame ES units.
regards,
Carlos
Old 28th February 2010, 01:37 PM   #157
Default On hiatus...ahahahaha!.... building!
This on hiatus remembers me the Swedish guy.....Halojoy.
ahahahahaha!
fine!
regards,
Carlos
Old 28th February 2010, 06:24 PM   #158
Default Dx TriAmp will have Blame
take a look.
regards,
Carlos
Old 1st March 2010, 08:27 AM   #159
Default 3-way active line level crossover, made by Marcisium Laboratories
for the Dx TriAmp.
24dB active crossover.
Dx TriAmp unit was dismounted to substitute some boards by the Dx Blame ES amplifier, the crossover you see down and left side....it is under re-construction.
regards,
Carlos
File Type: pdf 3-way active crossover - 24dB, by Marcisium Laboratories.pdf (32.2 KB, 55 views)
Old 9th March 2010, 08:00 PM   #160
lycanlk is offline lycanlk  Sri Lanka
Default Thank you uncle charly...
You are right ! This thread has a lot of information I'm worried about..
I'm reading one by one... and I will let you know my experiments...
regards,
Lycanlk
Dx TriAmp bass unitHide this!Advertise here!
Mission 720 bass unit repair Mark25 Multi-Way 27 24th January 2011 03:34 PM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 02:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 03:29 PM
Repairing bass unit in quad-63--HELP Williams Audio Planars & Exotics 2 14th October 2005 10:59 AM
Final 0.3 ELS bass unit and x/over systema Multi-Way 0 6th August 2005 06:56 AM
