Dx TriAmp bass unit
Dx TriAmp bass unit
Old 20th October 2009, 09:41 PM   #121
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default A forum friend, made the kindness to send me the software to build
active filters.
Let me know if you want it Gaetan.... around 3 Megabytes.
with the filter i can produce, easier, the active to test if they will sound better...i doubt a lot...but childrens (listening tests) will decide that stuff.
It is Filter Pro from Texas Instruments.
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 20th October 2009, 09:47 PM   #122
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Carlos, I don't rate me or you as audiophiles, simply because we listen to music how we like to hear and enjoy it.
Audiophiles listen to the equipment and need to prove to themselves it sould sound nice, but I sometimes don't think that they enjoy music, they enjoy sounds.
Neither of these religions are wrong, one is a little more radical than the other but it is what you believe is right for you.
Old 20th October 2009, 09:52 PM   #123
Nico Ras's Avatar
Geatan/Carlos,
don't you think passive filter is better, but adjust the amplifier gain a little to compensate for insertion loss. The losses in a passive filter is only 1 or 2 dB in the passband.
Besides passive filters do not generate noise, active filters does. In my set-up I started with active filters but at high levels I could hear the shhhh during quiet passages.
I changed to passive and adjusted the amp gain 2 dB up and there was no more noise. If you consider noise figure, the first stage is what determines the major noise of the system.
Kindest regards
Nico
Old 20th October 2009, 11:16 PM   #124
Default I have tested without the 10 ohms ground lift resistance..the lifted ground to the
input signal and i could listen noise too... them i have inserted the resistance back to place...in the reality i have removed the short i have made with wire across the 10 ohms resistance....now the noise reduced a lot..... hard to listen..i have to lift the volume all the way up and go 50 centimeters to the tweeter to listen.
regards,
Carlos
Old 20th October 2009, 11:30 PM   #125
Nico Ras's Avatar
Okay what is your point or is this related to an earlier post?
Old 20th October 2009, 11:35 PM   #126
Default Noises....i found the noises can be reduced by the lifted ground
but of course, not to producing, not to generating, not to use active may be more interesting.
The lifted ground, by itself can not be the medicine to noises..better not to generate them, not to produce them, not to use active devices, better go avoiding extra stages and so on.
You have agreement...i do not listen music.... i use to listen sound...also i play guitar but i do not know if Do, or Mi, or other tone...i just play the sound.
regards,
Carlos
Old 21st October 2009, 01:42 AM   #127
gaetan8888 is offline gaetan8888  Canada
Originally Posted by Nico Ras View Post
Geatan/Carlos,
Kindest regards
Nico
Hello Nico
Yes passive filter is better since no op-amp are in the signal path.
But somes passive filters can have phase anomalies problems and could be hard to get flat response.
Bye
Gaetan
Old 21st October 2009, 01:53 AM   #128
Originally Posted by destroyer X View Post
active filters.
regards,
Carlos
Hello Carlos
Thank, I did go at ti.com and there I did found Filter Pro.
I did have an old version of op-amp filter calculation but Filter Pro are better.
Bye
Gaetan
Old 21st October 2009, 05:50 AM   #129
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
...we have to take that drink around the swiming pool....do you remember?
hahaha you are right Carlos, and very good memory too, it's true we have to take that drink someday around the swimming pool with dancing chikas and Sangria, and when the Sangria is finished we will continue with Caipirinha until the sunrise... and your 3-channel amplifier tuned in with love will play Samba and Bossa Nova all night long, and after the party is over we will go inside and tweak the amplifier with more love for next night session!! hehehe
You know I was thinking about those CCS or resistors for the input differential stage, I was reminded once thinking I would use a huge resistor value and connect it to 1000 Volts source, actually I posted the idea here for a long time ago, I must one day try that crazy and dangerous idea! hehe
Cheers Michael
PS: If I come to Rio de Janeiro 2016 or another year I promise we will meet!
Old 21st October 2009, 07:56 AM   #130
Default heheheheh that's fine.
We gonna be waiting for you all folks, in Rio 2016...i promise and guarantee you will visit the second most pretty place in this world (first is Honolulu in Hawai)
Well...people say the world will finish in 2012..... december 22 i think, not sure..the Maya and Aztec calendar shows that day as beeing the last one.
We do not bother about what Maya and Aztec said.... their world already finished 500 years ago.... our world will finish, maybe drowned, because too much beer during the 2016 Olympic games.... people may have heart attack watching the girls passing by while sitted at Copacabana beach having beer and roasted sausages (wurst unt bratwurst, frite potatoes, sausage with onions and bread and baked frited provolone cheese and also some Calabrian sausage from Italy)...yessssss!
My memory is even better than the elefant's memory..sometimes they asked me things they forgot...mum gave me some medicine made using Cod liver oil when i was very young...i remember details while i was 3 years old and television advertising gingles from the fifties.
The 2016 Olympic games celebration vídeo drives me happy listening our drums...they are part of our Afro-american culture... those things are part of our genetic.
Cheers!
Hic!
Carlos
File Type: jpg Tira gôsto, food to have together beer.jpg (205.9 KB, 96 views)
Dx TriAmp bass unitHide this!Advertise here!
Mission 720 bass unit repair Mark25 Multi-Way 27 24th January 2011 04:34 PM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 03:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 04:29 PM
Repairing bass unit in quad-63--HELP Williams Audio Planars & Exotics 2 14th October 2005 11:59 AM
Final 0.3 ELS bass unit and x/over systema Multi-Way 0 6th August 2005 07:56 AM
