Dx TriAmp bass unit
The active filter have presented huge distortions in the midrange and treble
This way it will be fixed soon... already in contact with the designer in the Marcisium Laboratories.
This former crossover, the way it is today, cannot be aproved.
I am producing another active crossover to be tested, this one discrete.
You can see the treble unit.
regards,
Carlos
  • Dx active crossover, treble unit.pdf
This one uses Dx Amplifiers, or standard ones, together passive input filters
to produce a tripple amplifiers, having one channel for bass, other for mids and another for treble.
The active filter was tested and result not fine (that one)..we are developing/creating/copying/adapting, another active input crossover, using discrete components.
You can use other amplifiers..not only Dx amplifiers..the idea sounds very good, as reducing bandwidth to each one of these amplifiers, you also reduce distortions.
regards,
Carlos
