Dx TriAmp bass unit
Dx TriAmp bass unit
Old 19th October 2009, 03:04 PM   #101
Ultima Thule is offline Ultima Thule  Europe
Ultima Thule's Avatar
Originally Posted by destroyer X View Post
...There’s no problem about you Ultima Thule..you are not such
kind of guys, but your question made me suspect you may be addicted
to such kind of group of ideas…. ...
hahaha thats ok!
You manage to make a second reply while I was typing on my reply...
sure I understand what you mean, some times we should all be able to relax and just listen to music, and not the amplifier!
Cheers Michael
PS: Carlos, I'm very happy you got the Olympics 2016!
Old 19th October 2009, 03:34 PM   #102
pacificblue is offline pacificblue  Germany
the ratio is 60 percent to the woofer, 30 percent to the midrange and 10 percent to the tweeter....in watts this means 60 watts, 30 watts and 10 watts
That is the wrong conclusion. The reason, why you need less power for the tweeter, than for the woofer lies in their different sensitivities. Your tweeter has easily a 10 dB higher sensitivity than the woofer. That is, why you need about ten times the power for the woofer than for the tweeter.
The 60/30/10 ratio describes, how the load is distributed. If you had three drivers with the same sensitivities, they would need the same 100 W peak amplifier power for a flat frequency response. But their average power handling would be 60 W for the woofer, 30 W for the mid-range and 10 W for the tweeter.
The sensitivity changes that ratio. If you use a tweeter with 10 dB higher sensitivity in that configuration, it only needs 10 W peak amplifier power and 1 W average power rating.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 19th October 2009, 05:08 PM   #103
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Thumbs up Thank you Ultima Thule..you are very welcome
Yeah Ultima.... we've got the Olimpics..we gonna be the town..we are extremelly proud of that....happy as a morning bird because of that...in special we have winned Madrid...and we all know was a huge battle to win Madrid!.
In the Dog's face hill, under the rigth ear, they found Viking letters saying someone that died and was buried there.
a hug to you Ultima...we have to take that drink around the swiming pool....do you remember?
Carlos
You're wrong PacificBlue.... try to do it, build something alike, and you will see that even driver's sensitivity will not be the issue to balance a lovely system.
be happy!
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 19th October 2009, 05:50 PM   #104
gaetan8888 is offline gaetan8888  Canada
Those passive filters uses low voltage capacitors, and they use to be very cheap....also a single resistance or two will not be expensive.
What i do not know, for a while, is the sonic advantage for passive or active...i have to assemble both and compare.
Active can have higher level of attenuation, i do not know if i need that or not..i suppose not.
Passive distorts...but integrated circuit also distorts.
Passive does not need supply, when active will need a 12 volts symetrical supply.
I am not sure...but i think passive is natural.... seems more simple... and simple use to be better...we gonna see in the future.
Also, all of you can try and post your thougths about.
regards,
Carlos
Hello Carlos
Wen it's possible, I prefer to use passive filters, because active filter use op-amps and those do have a kind of sound signature and op-amp mostly need lot of feedback. If you need to use active filter use Bessel type to get better transient response.
Bye
Gaetan
Old 19th October 2009, 05:59 PM   #105
Default I do feel this way.... i will produce active too, because a friend asked
and i will be sure about all those things....i am not sure, there are some "attraction".....there are something very fashion when we use op amps...people believe high technology is hidden inside those black cases...big black magic there!....you know.... imagination can feed all kind of people needs.... whatever people wants.
In the reality, inside op amps we have an audio amplifier..with differential input (modified), voltage amplifier single or symetrical, drivers and output..all that stuff and an enormous ammount of ccs, mirrors, current sinks, stabilizers, impedance matchers (buffers) and so on..... in my imagination, all that stuff may distort more than resistances and capacitors...but...i am not sure in advance to build and test.
regards dear Gaetan.
à bientôt
Charles
Old 19th October 2009, 06:08 PM   #106
Hello Carlos
Which op-amps do you have in your parts bins ?
Bye
Gaetan
Old 19th October 2009, 08:28 PM   #107
Default Man!... i have several
Here you will see some of them... also i have the 4558 and 4560 and some numbers alike... the old family.
Some are alike small bugs...hard to hold between the fingers...i really do not like that stuff!... to read the numbers i have to find magnified lenses.
regards,
Carlos
Old 19th October 2009, 08:30 PM   #108
Default Here you have some more.
attached,
regards,
Carlos
Old 19th October 2009, 11:14 PM   #109
Hello Carlos
Same for me, I don't like those SMD Ic's, they are so small.
The 4558 and 4560 are not very good.
LM5532 and LM5534 are old but good, you can bias them in class A.
The LM4562 are very good but need good decoupling.
There was a good page about op amps but was close, but here is the page in
web archive;
Opamp Design
Bye
Gaetan
Old 19th October 2009, 11:43 PM   #110
Default Thank you Gaetan
The TriAmp playing at nigth.
regards,
Carlos
Dx TriAmp bass unitHide this!Advertise here!
Mission 720 bass unit repair Mark25 Multi-Way 27 24th January 2011 04:34 PM
Help for bass unit incloser pra3718 Subwoofers 4 23rd January 2009 03:45 PM
Cracked bass unit nfcgfm Multi-Way 3 17th April 2008 04:29 PM
Repairing bass unit in quad-63--HELP Williams Audio Planars & Exotics 2 14th October 2005 11:59 AM
Final 0.3 ELS bass unit and x/over systema Multi-Way 0 6th August 2005 07:56 AM
