Old 5th October 2009, 11:36 PM   #1
rtill is offline rtill  United States
Default driver caps 100 watt PA
curious about http://sound.westhost.com/project3a.htm
the driver caps are 100 pf on the bd140 transistors
what do these caps do? If I change them to a higher value (470 pf), will I get a duller sound?
I read on one of these forums that a higher value will "suck the life" out of the transistors....I don't know what that means.....
Thanks!
Old 5th October 2009, 11:49 PM   #2
nigelwright7557's Avatar
The first one is a miller capacitor.
It basically slows down the slew rate so you dont get oscilation.
An amplifier is similar to a servo system and a servo system requires just the right amount of gain. Too little and the output is sluggish, too much gain and you get oscilation.
If you increase the capacitors you will lose some high frequencies.
If you decrease the capacitor you could get oscilation.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
paralleling film caps with electrolytic caps jarthel Power Supplies 381 10th March 2012 08:13 AM
Replacing multi-section caps with multiple caps? Sir Trefor Tubes / Valves 1 29th May 2007 10:17 PM
Is 100 watt amp big enough for this driver? oddjob7 Subwoofers 15 2nd March 2006 07:50 PM
3 watt led driver magudaman Power Supplies 2 1st October 2005 11:22 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 01:02 PM
Page generated in 0.06369 seconds (67.58% PHP - 32.42% MySQL) with 10 queries
